Old 07-27-2009, 09:45 PM   #1
craigger
Drives: 2010 LS
Software upgrade to put 20" polished aluminum wheels/tires on LS?
Hello everyone and thanks in advance for any replies that you post. I was told by two separate dealers that I could replace the stock 18" black steel wheels/tires on the LS I bought with the 20" polished aluminum wheels/pirelli tires that come with the RS package (and an add'l approx. $500 upgrade cost) on the LT/SS. So, I order the wheel/tire package from Ebay and low and behold when I go to have them installed, the dealer says that the software upgrade has not been released by GM. The dealer searched on some website and the only authorized sizes for the LS are 18" (stock) and 21" (very expensive and I actually like the 20's a lot better), so I can't understand why the 20's won't work if 21's will. Does this have something to do with preset computer levels on the vehicle? This is very frustrating because my car is silver and would look so much better with the polished aluminum. Any ideas???
craigger is offline   Reply With Quote
Old 07-27-2009, 09:51 PM   #2
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
measure the height of the stock tires and the new ones. you should find that the overall tire height is going to be the same or very close and should not cause any issues just bolting them on,, you really shouldnt need any programming
Old 07-27-2009, 10:11 PM   #3
HeavyChevss
Drives: 71 Heavy Chevy SS454
I'm sure I read in the dealer's sales guide that all of the wheel/tire packages had the same tire height. If they are the same height I don't see why a software change would be needed?
Rick
HeavyChevss is offline   Reply With Quote
Old 07-27-2009, 10:20 PM   #4
Parker
Parker's Avatar
Drives: 2010 Camaro SS/RS
Even if the tread diameter is different on most new GM cars you can change the tire settings with a Tech 2 hooked up. So you should see if the size you want is available in the in the computer's settings.
Parker is offline   Reply With Quote
Old 07-28-2009, 01:35 PM   #5
stovt001
stovt001's Avatar
Drives: 2006 Cobalt, 2004 Taurus wagon
Tire height should be the same, so I don't see why it should be a problem. Just be prepared for a performance downgrade, as those 20 inch wheels are stupid heavy.
"It's kind of fun to do the impossible" - Walt Disney
There's a great big beautiful tomorrow
shining at the end of every day
Just a dream away
stovt001 is offline   Reply With Quote
Old 07-28-2009, 02:19 PM   #6
PieNsky
PieNsky's Avatar
Drives: Victory Red 1LS
And the LS has the 18" steelies so I would think that they would be heavier just going by the official weights of the Camaros, the LS weighs more than the LTs.
PieNsky is offline   Reply With Quote
Old 07-28-2009, 03:20 PM   #7
Dynabyte
Dynabyte's Avatar
Drives: 2014 2SS/RS/NPP Red Hot
The upgrade is probably to increase the max MPH limiter - It's 155 with the 20s but a lower amount with the 18s/19s (if I recall correctly). Another reason to get the RS package with V6s
Dynabyte is offline   Reply With Quote
Old 07-28-2009, 05:33 PM   #8
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
bingo i think you got it
Gentry78 is offline   Reply With Quote
Old 07-28-2009, 10:44 PM   #9
jvmax
jvmax's Avatar
Drives: 2010 Camaro LS
I ordered the LS with the same thinking. What I did was changed the tires in my driveway with a floor jack. Once I did this I got a "check tpms system" in the driver info system. Tried to manually reset the system to no avail. So I took the it to the dealership (not the one I bought it from). told them I had an error in the tpms system, they had to replace one bad sensor in the rear wheel before they could reset system. Service guy told me if anyone asked, I bought the car with the 20's on it. So, a $240 service was covered for free under warranty.
all in all, I suggest doing what i did.
Rally LS Transformer
jvmax is offline   Reply With Quote
Old 07-29-2009, 04:44 PM   #10
tededfred
tededfred's Avatar
Drives: 2010 Rally Yellow Camaro 2LT!!
I don't know anything about the software update, but are any of you guys taking off the LS rims looking/willing to sell them? I need a set to put winter tires on! I'm sure we could work something out
tededfred is offline   Reply With Quote
Old 07-29-2009, 08:12 PM   #11
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
What model do you have TedEdFred? Those 18"-ers will only fit a V-6 due to the brakes on an SS.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 07-30-2009, 10:29 AM   #12
tededfred
tededfred's Avatar
John B.
yep, i know about that. I have a 2LT on order, so the 18"s should fit
POLISHED ALUMINUM v. MIDNIGHT SILVER SuperSport2010 Wheels and Tires Talk Sponsored by The Tire Rack 15 06-10-2009 08:06 PM
Polished Aluminum or MSS Riderover40 5th Gen Camaro SS LS LT General Discussions 6 03-19-2009 07:11 AM
