Old 03-08-2014, 10:44 AM   #1
Camarosrock
Drives: None anymore, sadly
Has anyone ever fitted a lightweight flywheel?
Hello,
Well, the title pretty much says it all. I don't know if this topic has been discussed before, as I can't seem to get to grips with the search function here. But would be interested to know if anyone has ever fitted a lightweight flywheel, and what the experiences with it were like.
Camarosrock is offline   Reply With Quote
Old 03-08-2014, 02:07 PM   #2
B-_-RAD
Banned
Drives: ...
These cars are a little heavy for that IMO. The extra mass helps get these pigs moving.
B-_-RAD is offline   Reply With Quote
Old 03-08-2014, 03:25 PM   #3
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
I installed a dual disk clutch/flywheel combo that weighed about 18 lbs less than the stock items. There is a learning curve of feathering the clutch and applying a little more throttle, but now I don't think about it any more, it seems normal.
Cam 427 is offline   Reply With Quote
Old 03-15-2014, 12:15 PM   #4
Camarosrock
Thanks for the replies.
I would also be interested whether it made a noticeable or substantial improvement in acceleration.
If it is the only mod I am planning in the entire drivetrain, does it require any sort of engine recalibration?
Thanks again.
Old 03-16-2014, 06:27 AM   #5
sutherlacd27
Drives: 2010 Camaro SS
Thanks again.
message Steve at snl about your question. He will tell you everything you need to know.
sutherlacd27 is offline   Reply With Quote
Old 03-16-2014, 07:11 AM   #6
TrekGTO
TrekGTO's Avatar
Drives: 05 GTO / JETTA TDI
I have the Monster light weight in my LS2 I know Steve does not recommend them. I used light weight in my air cooled VWs forever but I think that made more sense.
TrekGTO is offline   Reply With Quote
