Old 03-09-2014, 10:16 AM   #1
ender2664
Drives: 2016 2SS
lightweight
Are the any rotors on the market that drop a decent amount of weight?
I really don't know how to drop rotating mass besides a aluminum drive shaft, pullies and rotors.
ender2664 is offline   Reply With Quote
Old 03-09-2014, 11:18 AM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Racing Brake rotors. They are 26 lbs lighter than OEM. Apex-Speed has the best price on them btw.
Click to view my build thread
Old 03-09-2014, 11:52 AM   #3
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
There aren't really any options for the v6 brakes. I have some R1 Concept rotors and after replacing all 4 I only saved a little over 3lbs. If money isn't an issue then I would upgrade to the brembos and then buy the Racing Brake rotors that were mentioned.
kjkjr27 is offline   Reply With Quote
Old 03-09-2014, 12:00 PM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Racing Brake is the lightest option I am aware of and they perform great as well. You can save a lot of rotating mass with wheels and tires as well.
Old 03-09-2014, 12:52 PM   #5
tanur420
Drives: 2011 Camaro SS
Isnt the equation supposed to be,roughly, 1 lb of rotational weight is worth 10 lbs of regular weight and shaving 100 lbs of.regular weight is worth .1 in your 1/4? Talking about shaving off a 1/4 second. Not a cheap way to get faster but hey it works
tanur420 is offline   Reply With Quote
Old 03-11-2014, 07:49 PM   #6
ender2664
Drives: 2016 2SS
26lbs I assume is 6.5 at each corner, right?
Old 03-11-2014, 07:50 PM   #7
ender2664
Drives: 2016 2SS
I am sure it is probably posted on here somewhere, but is there a list of rim weights?
Old 03-11-2014, 08:34 PM   #8
ender2664
Drives: 2016 2SS
Is there a calculation for how much 1lb of rotating mass shaves?
Or does it depend on speed, diameter rotating and other stuff
Old 03-11-2014, 09:22 PM   #9
tanur420
I said .1 in your quarter time per 10 lbs of rotational weight. 26 ,lbs would be .26 which os just over a 1/4 second off your 1/4 mile time
Old 03-12-2014, 03:47 PM   #10
toehead93
Drives: 2014 2SS/1LE
had the racing brake rotors on my 2010 SS and they are nice. In fact I have them for sale now, see my sig. They will get you the most weight reduction of any rotors I have seen and they run cooler than others as well.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 04-17-2014, 12:17 AM   #11
ender2664
Drives: 2016 2SS
You still selling those?
Old 04-17-2014, 09:37 AM   #12
Apex Motorsports
That is only taking into consideration straight line acceleration but reducing weight, specifically rotating mass that is also unsprung weight, improves performance across the board; acceleration, handling, and braking. Not to mention that the rotors themselves will perform better than stock and run much cooler.
5.5 off each of the front rotors and 6 of each rear.
Old 04-17-2014, 03:52 PM   #13
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
Tru Dat! Mine should be here tomorrow! Then MSR Houston on the 3rd.
jeremywes is offline   Reply With Quote
