Old 03-09-2014, 10:18 PM   #1
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
SS springs vs. ZL1 springs
What's the big difference between 2010 SS springs and 2013 ZL1 springs will I get a drop an will I get a stiffer ride???
Old 03-09-2014, 10:20 PM   #2
Sapper12b
HTCC Member
Sapper12b's Avatar
Drives: 2013 Camaro SS
YOu know , I started to think about this the other day. Curious to know the answer myself.
Sapper12b is offline   Reply With Quote
Old 03-09-2014, 10:55 PM   #3
RED_SS
RED_SS's Avatar
doesnt the ZL1 have the mag ride? So wouldnt it be completely different? Or is the 2014 the mag ride...
2013 SS - LS3 | ADM Intake | Stainless Power LTs | 227/239 : 114 | Ported TB | Spintech Super Pro | 160* Stat | Hurst Short Throw | 1LE Sways | Factory ZL1 Reps | Quality Motorsports Tune
RED_SS is offline   Reply With Quote
Old 03-09-2014, 11:34 PM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
That's the strut not the spring
Old 03-09-2014, 11:35 PM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
http://www.camaro5.com/forums/showthread.php?t=242039
Found this seems like there's a few cons according to spring MFGs but from the every day guy it seems lime a win win
Old 04-17-2014, 11:21 AM   #6
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
To revive a semi-old thread, it seems like it's quite the upgrade for the V6 guys, but the jury is still out for the SS's. Anyone else try this?
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 04-17-2014, 07:27 PM   #7
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
I have ZL1 springs on my car. They give it a firmer ride, lowers the front 10mm and the rear 15mm.
Eddiefuzz is offline   Reply With Quote
