Old 03-23-2014, 12:55 AM   #1
Lio Martinez
Drives: 2013 Camaro 2SS RS 1LE IMO Turbo
Sparco Racing seat Project 1LE
New 1LE project for Track
Upcoming project will include New Sparco Evo 2 Red seats, Sparco 6 Point Harness and Tank plates as well as a Speedware Harness bar
Stay tuned !!
Lio Martinez is offline   Reply With Quote
Old 03-23-2014, 08:54 AM   #2
BATMOB1LE
• HT •
BATMOB1LE's Avatar
Drives: 2013 2SS/RS 1LE
Subscribed!
2013 Camaro 2SS/RS/1LE - 402 of 451
"BATMOB1LE"
- Xpel Stealth Wrap - ZL1 Rockers - 18% Tint - Custom Badges - Heritage Grille - BMR 1.4" Springs - Solo Performance Axel-Back Exhaust - Recaro Sport Seats
BATMOB1LE is offline   Reply With Quote
Old 03-23-2014, 09:11 AM   #3
Novie LE
Drives: 2014 1LE
Very interested in this, especially the headroom part.
2014 Red Hot 1LE
Novie LE is offline   Reply With Quote
Old 03-23-2014, 01:48 PM   #4
Lio Martinez
I been checking different websites for prices and I was luck enough to find a website where the seats and harness from Sparco are 10% cheaper
http://speed-freaks.net
Found the Evo 2 seats for $720 instead of the usual $825. And the 6 point harness for $323. Instead of $360.
I'm still deciding if I will get the RPM roll cage
http://rpmrollbar.com
The Brey-Krause harness bar
http://www.mtiracing.com/brey-krause...en-camaro.html
Or the Speedware harness
http://www.speedwaremotorsports.com/...ess-bar?page=1
If I use any harness bar I will need tank plates to support the harness . If I use the roll cage I will need two seat belt kits that RPM sells.
The only trouble I see ahead of this project is the disabling of the air bags because of the removal of the front seats.
Old 03-23-2014, 01:49 PM   #5
Deftones
Deftones's Avatar
Drives: 2012 RS/SS LS3
Nice seats
Deftones is offline   Reply With Quote
Old 03-23-2014, 01:59 PM   #6
B-_-RAD
Banned
Drives: ...
A 1k ohm resistor should be enough to trick the air bag computer into thinking the seat airbags are there and keep everything active.
B-_-RAD is offline   Reply With Quote
Old 03-23-2014, 03:51 PM   #7
Lio Martinez
Where could I get a resistor like that? And where do I connect it.
By the way thanks for the help
Old 03-23-2014, 04:13 PM   #8
Lio Martinez
Old 03-23-2014, 07:24 PM   #9
crangie
crangie's Avatar
Drives: Camaro ZL1 #641
This would only help if you change the driver seat only. if you change the passenger seat you have to additionally emulate the weight sensor mat.
crangie is offline   Reply With Quote
Old 03-23-2014, 07:34 PM   #10
Lio Martinez
Yeah in doing both. So how do I do that?
Old 03-23-2014, 08:01 PM   #11
Billy10mm
Billy10mm's Avatar
Drives: 2014 Camaro 2SS 1LE NPP
A 1k ohm resistor can be picked up at any Radio Shack or other electronics hobby shop. https://www.sparkfun.com/products/8980 You would need to find the wiring diagram for the OEM seat and use the resistor to bridge the positive and negative terminals in the wiring harness.
As far as the pressure sensor goes, pressure sensors can work in a few different ways, but many work by simply changing their resistance depending on the amount of force provided. One thing you can try is picking up a few different kinds of resistors and connecting them to the harness and then check to see if the car thinks someone is in the seat or not (I assume there's some sort of indicator lamp somewhere to tell you whether or not the passenger airbag is activated).
Alternatively, you could carefully disassemble the OEM seat, find the OEM pressure sensor, and put it in the new seats running the leads out to the car's wiring harness.
https://www.sparkfun.com/products/9376
Billy10mm is offline   Reply With Quote
Old 03-24-2014, 11:20 AM   #12
crangie
crangie's Avatar
I am currently working on a DIY for those.. Passenger is a challenge but I think I got it figured out, just have the get the parts to build and confirm it
the driver is easy.
Old 03-24-2014, 08:03 PM   #13
Stock Boy
Stock Boy's Avatar
Drives: 2014 1LE
Awesome thread. What kind of rails are you using?
Stock Boy is offline   Reply With Quote
Old 03-24-2014, 08:42 PM   #14
Lio Martinez
Don't know specifically if that question was directed to me. But I'll be using the
Sparco Seat Base 600 series
Specifically made for the 5th Gen Camaro and are different from Driver to passenger side.
"Sparco Seat Bases utilize the factory seat mounts on your vehicle's floor and provide a flat surface for mounting your Sparco seat. All seat bases are vehicle specific and provide a 100% bolt-in installation.
The 600 Series Sparco seat base is constructed with 3/16" thick steel to provide a strong flex-free mount. In addition to the mouting holes provided for standard bolt-on installation, the Sparco base has a wide metal platform to allow custom mounting of side mounts direct to the base (drilling required). This direct installation is an option for race vehicles where the lowest seat position is desired. The base is powder coated in a black wrinkle finish. "
Sparco Side mount steel
"Sparco side mounts are used to mount competition seats. Side mounts have mutliple side holes that provide a customizable mounting position. "
And the Sparco Track set
"The track set also known as sliders are recommended for any seat application. The seat track set allows you to adjust the seat position. The seat tracks employ a double locking mechanisim for increased safety."
In order to properly install a Sparco seat in your vehicle, you will need one (1) of each of the following, per seat:
Bottom Mount Seat (Street Series Seats)
-Seat Base (600 series)
-Track Set (#00493)*
-Bottom Mount Hardware Kit (#50001)
Side Mount Seat (Competition Series Seats)
-Side Mount (steel #004902 or aluminum #600W)
-Side Mount Hardware Kit (#50002)
*The Track Set allows for forward and backward adjustment of the seat
