Old 04-04-2014, 07:01 PM   #1
SERVED_USMC
SERVED_USMC's Avatar
Drives: Slow
Oil Pan Rivets
There are 2 on the pan to help keep the gasket in place. Are these necessary and do they need to be re installed once I drill them out throw a new gasket in?
ETA: Also not that I have the motor out of the car and a new shortblock going in so this will all be done on a stand.
SERVED_USMC is offline   Reply With Quote
Old 04-04-2014, 07:12 PM   #2
trw427ss
trw427ss's Avatar
Drives: 2013 2SS/RS L99
No need to reinstall them just put on the new gasket.
2013 2SS/RS L99/A6 Crystal Red Metallic Tincoat 12.76@108.98mph Bone Stock
12.46@111.19mph with New Era CAI & U/D Pulley
12.12 @ 114.16 after Stainless Power headers and no tune yet on stock P-Zero's!
12.007@ 115.20 With 18" Drag Radials - 11.93 @115.19 Added a PTB 11.76 @116.59 With Yank SS3200 Converter - 11.63 @116.52 After PI and Tuning 11.44 @118.75 New Best
10.72 @127.93 after heads and Cam and Yank SS3600
trw427ss is offline   Reply With Quote
Old 04-04-2014, 07:14 PM   #3
trw427ss
trw427ss's Avatar
Make sure to square the back of the pan with the back of the block!
Old 04-04-2014, 07:15 PM   #4
lynxone
lynxone's Avatar
Drives: 2012 2ss 45th anniversary edition
I reinstalled them when I replaced my gasket. I really don't know if they are necessary or not but it only takes a few minutes so I figured why not. What method did you use for dropping the pan? Did you pull the motor, remove front cradle, or did you modify the crossbar?
Sent from my iPad using Tapatalk
2012 2SS 45th with a few tasteful mods
lynxone is offline   Reply With Quote
Old 04-04-2014, 07:16 PM   #5
lynxone
lynxone's Avatar
Eh...never mind, for some reason your entire post didn't display on my iPad
Old 04-04-2014, 07:20 PM   #6
SERVED_USMC
Drives: Slow
I threw in an edit, so it probably wasnt up yet.
I broke a lifter so the motor had to come out. Pulled off everything from the heads up and pulled it out of the top.
Old 04-04-2014, 07:24 PM   #7
lynxone
lynxone's Avatar
That sucks about the lifter. I re-engineered the cross brace to be removable to drop mine. I had to replace the pick up tube. Still have to lift the motor a bit (inch or two) but much easier for next time it needs a new gasket. It's pretty stupid they designed it like that.
Old 04-04-2014, 07:38 PM   #8
trw427ss
trw427ss's Avatar
On a 5th gen camaro we pull the intake, water pump and accessories off and pull the engine out and put it back in the same way.
Old 04-05-2014, 05:42 PM   #9
SERVED_USMC
Drives: Slow
Thats how I plan on putting it back in. It only took a little extra time to pull off the heads. Didnt know how tight it would be with them on.
Old 04-06-2014, 02:02 AM   #10
trw427ss
trw427ss's Avatar
Its no problem at all with the heads on!
Old 04-06-2014, 05:03 PM   #11
BLACK10
BLACK10's Avatar
We always re install the rivets back onto the oil pan just as it comes from the factory. It assures the pan gasket stays in proper alignment.
