Old 04-06-2014, 07:32 AM   #1
gglefty
Guest
Posts: n/a
List of all Service Bulletins (TSB), Recalls, and Major fixes
All - My warranty is expiring, and was looking in this forum for a comprehensive list of TSB's, recalls, and Major fixes needed, but haven't been successful. Here are the things I've found:
Convertible TOP Recall Bulletin No.: 12052
http://www.camaro5.com/forums/showthread.php?t=214163
Paint Door vs. panel Appearance Bulletin 2346049
http://www.camaro5.com/forums/showthread.php?t=42941
TSB 09-08-51-005 "Rear Bumper Fascia Contacting Body, Peeling Paint"
http://www.camaro5.com/forums/showthread.php?t=67766
#PI0027: Rattle Noise Under Vehicle Exhaust
http://www.camaro5.com/forums/showthread.php?t=82049
Strut Tower Paint Discoloration (no official TSB found)
http://www.camaro5.com/forums/showthread.php?t=156717
Are there any others I'm missing?
Thanks in advance for any additional info.
Old 04-06-2014, 08:28 AM   #2
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
Wasn't there one for an airbag reflash?
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 04-06-2014, 01:24 PM   #3
gglefty
Guest
Posts: n/a
Thanks.. yes, looks like this was a service bulletin for the 2010 first year, so worth adding here to make sure it's already taken care of.
Service Bulletin #PIC5281: Intermittent SIR Light on History Codes
http://www.camaro5.com/forums/showth...t=32540&page=4
Old 04-12-2014, 07:09 AM   #4
Chevy_cowboy
Chevy_cowboy's Avatar
Drives: 2011 IOM 2SS/RS M6 Convertible
I'm not sure if its a TSB or not but the trunk lid cable and wiring harness cutting the weatherstripping is a problem on early convertibles... thats one I need to get taken care of on ours before the warranty is up.
Chevy_cowboy is offline   Reply With Quote
Old 04-12-2014, 07:27 AM   #5
6bangerBOOM
6bangerBOOM's Avatar
Drives: 2016 1SS SW
Happens on coupes too. I don't think it was a TSB but it should have been something.
6bangerBOOM is offline   Reply With Quote
Old 04-12-2014, 01:48 PM   #6
DefianceDan
VroomVroom
DefianceDan's Avatar
Drives: 2017 50th 2SS
Don't forget the wet sock in the AC/after-blow module one.
2017 H50 2SS MX8 F55 NPP CF5 RN2
DefianceDan is offline   Reply With Quote
Old 04-14-2014, 01:19 PM   #7
gglefty
Guest
Posts: n/a
Haven't found this issue in any searches. If any of you find the link to the details please post them here. Thanks!
Old 04-14-2014, 01:21 PM   #8
gglefty
Guest
Posts: n/a
The wet sock TSB is noted.
Old 04-14-2014, 01:25 PM   #9
Chevy_cowboy
Here's the thread I saw about it, never did hear if there was an official TSB on it. http://www.camaro5.com/forums/showthread.php?t=339554
Old 04-14-2014, 09:35 PM   #10
gglefty
Guest
Posts: n/a
Gotcha.. Perfect timing.. car's already at the shop! I'm gonna look at it tomorrow.. thx for heads up!
