Old 04-07-2014, 01:01 PM   #1
Raymundoseis
Drives: 2014 camaro 2lt
2014 Camaro 2lt w/ dual mode rattle?
I was wondering if anyone here with a 2014 camaro with dual mode exhaust has been having the same issue. I took it to the dealer and they swapped my whole exhaust and it continued to rattle so they said it must be the way they are manufacturing the exhaust and they cant do anything until gm finds a fix for it ... Its just the flap that open and closes in the exhaust that is making that rattle and they say they cant do anything wth?!?!
Raymundoseis is offline   Reply With Quote
Old 04-07-2014, 03:15 PM   #2
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
why don't you just pull the fuse?
maddoggyusa is offline   Reply With Quote
Old 04-07-2014, 03:21 PM   #3
Raymundoseis
Im sorry im new to this -.- what does that mean?
Old 04-07-2014, 03:34 PM   #4
Raymundoseis
I just read about pulling the fuse. But if i pull the fuse the flaps will stay open and thats the problem. When the flaps are open is when the rattle starts -.- ...but its worth a try. Does anyone know where the fuse is located for the flaps to stay open on my exhaust?
Old 04-07-2014, 06:46 PM   #5
maddoggyusa
it's in the trunk behind the carpet... here's another thread on the procedure.
http://www.camaro5.com/forums/showthread.php?t=268970
Old 04-08-2014, 03:04 AM   #6
the barber
the barber's Avatar
Drives: 13' Sw 2ss Ls3
Try tightening up the clamps right behind the cats. If u still have the problem I think theres some sort of clamp where it holds up the exhaust to the body and what u do is remove that clamp/bracing and install some spacers to try and get the exhaust from rattling from under the body of the car.
the barber is offline   Reply With Quote
Old 04-08-2014, 11:35 AM   #7
Raymundoseis
Its not the exhaust that is hitting the body of the car. Its the flap inside the exhaust. The best way i can explain the sound is if u were to get a key and hit the exhaust gently numerous times. Thats how it sound in low rpms . Its so annoyig
Old 04-09-2014, 02:12 PM   #8
Kami2014
Kami2014's Avatar
Drives: 2014 Convertible 2LT BRM RS
Same issue. Just didn't know where the noise was coming from besides the rear end. Not occurring all the time though. Doesn't bother me too much but will follow the thread to see what Chevy suggests.
Kami2014 is offline   Reply With Quote
Old 04-10-2014, 11:53 AM   #9
Raymundoseis
Does urs have dual mode exhausy as well??
Old 04-10-2014, 09:09 PM   #10
Kami2014
Kami2014's Avatar
Yes I have the dual mode exhaust on my 2014 2LT RS.
Old 04-10-2014, 10:36 PM   #11
GDSPEED
GDSPEED's Avatar
Drives: 2014 2LT/RS
i noticed this happening on mine the other day as well. I have the Mild2Wild exhaust switch installed on mine, but i've only noticed it on start up it seems.
GDSPEED is offline   Reply With Quote
