Old 04-16-2014, 11:03 AM   #1
Zhaoyu Chen
Zhaoyu Chen's Avatar
Drives: 2013 camaro ss L99
A question about LT headers+corsa catback bolts on
Hi guys i have a 2013 L99 camaro ss with the Livernois Motorsports stage 2c cam package. They used LT headers connected with corsa catback using clams and bolts. The car was very nice until recently the catback fell off from the high flow cats of LT headers. Livernois has put the exhaust back and used new clams and bolts. They said they had over torqued the bolts and thats why the exhaust fell off and now they torque the bolts the right way. Have anyone else using bolts-on LT headers and exhausts experienced such falling off? Should I just weld the connections? I just wonder whether clam and bolts can hold the exhaust and headers.
Zhaoyu Chen is offline   Reply With Quote
Old 04-16-2014, 12:41 PM   #2
Gillis
Drives: Car
I'd say it's due to them using clams.
Gillis is offline   Reply With Quote
Old 04-16-2014, 12:45 PM   #3
sscamaro
Drives: 2010 2SS, 2017 Silverado LTZ
I used the clamps that came with the LT headers & hi flow cats on 3 sets of headers and none ever fell off.
sscamaro is offline   Reply With Quote
Old 04-16-2014, 12:47 PM   #4
Zhaoyu Chen
Do you recommend welding the exhaust and the headers?
Old 04-16-2014, 12:51 PM   #5
Zhaoyu Chen
Okay I think I will just wait and see how the reconnection works. Do you drive agrresively?(i guess u do) How many miles do u have after you install the headers? Thanks!
Old 04-16-2014, 12:54 PM   #6
Zhaoyu Chen
sorry i misspelled the word clamp......thats what you mean right?
Old 04-16-2014, 01:10 PM   #7
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
No.. Use the Clamps. We will usually tighten down the clamps and then go back and re-tighten everything after a few heat cycles. The clamps will provide a good hold if installed properly.
Best regards,
Tyler
888-308-6007
Old 04-16-2014, 01:24 PM   #8
sscamaro
Yes, I drive aggressively. I have 40K miles on the SS now and it only had about 100 miles on it when I installed the Kooks LT headers.
Old 04-16-2014, 01:25 PM   #9
Zhaoyu Chen
Best regards,
Tyler
888-308-6007
Okay got it! The guy from Livernois did not recommend welding the exhaust either. Thanks for your advice.
Old 04-16-2014, 01:28 PM   #10
Zhaoyu Chen
Great! Did you re-tighten the bolts again after you install the headers?
Old 04-16-2014, 03:02 PM   #11
Andy@Livernois
Andy@Livernois's Avatar
Drives: 1987 Buick Regal Turbo-T
Just for clarification for everyone, the bolts that were overtorqued were ones installed by another shop, not the part that we installed. They were so overtightened the bolt had stretched. We replaced the clamps with ones we had here to correct the problem.
Andy@Livernois is offline   Reply With Quote
Old 04-16-2014, 03:19 PM   #12
Zhaoyu Chen
Alright man sorry for not making it clear that it was not your problem and thanks for fixing the problem. Do you think I need to re-tighten the bolts after certain miles? If you do, how many? Thanks a lot!
Old 04-16-2014, 03:45 PM   #13
Squillo
Drives: 2013 Camaro 2SS/RS BRM LS3
You should never use seafood to attach parts to your car.
Squillo is offline   Reply With Quote
Old 04-16-2014, 06:37 PM   #14
Andy@Livernois
we heat cycle the car a few times between the dyno, and street driving that we do, so I personally wouldn't worry too much about the clamps. If you're ever in the area and are worried though, we can always throw it up on the hoist to give you peace of mind on it
catback, corsa, livernois, lt headers
