Old 05-06-2014, 07:01 PM   #1
moiy1983
moiy1983's Avatar
Drives: 2010 camaro ss/rs
ZL1 Diff swap?
Has anyone installed the Zl1 upgrade kit offered by GM? If so was it a compete kit? Was there any modifying of the stock k member ? What kind of HP are you putting down & what driving habits and or drag racing have been done with this kit?
CAMARO ZL1 HD DRIVELINE KIT
MANUAL TRANSMISSION — P/N 22959394 /
2010 SS @gt_klr Built by Jrod Tuned by Matt Sorian
LSX 434 by HKE Dragon Slayer, Callies ultra rods, Wiseco Coated Pistons, Mast 285cc LS7 Heads
ProCharger F1-X
Nitrous Outlet Direct Port
Fore Innovations Triple Pump on E85
Alky Control Meth Injection
ProEFI ECU
Stainless Works 2" Headers with Corsa 3" Exhaust
RPM 4l80e with Jakes Transbrake
BMR Everything with 15" Conversion
Zl1 Front Brakes & Carlyle Racing Rear Brake Kit
Weld Wheels
moiy1983 is offline   Reply With Quote
Old 05-06-2014, 09:59 PM   #2
smokum
smokum's Avatar
Drives: 2010 2ssrs
I have seen a bunch of cars around dfw are with these. I had the lingenfelter setup in my car. I opted for the gm engineered parts. Zl1 3.73 going in my car. I talked to the gm guys down at c5 fest about the development of the zl1 diff. I was told that they were looking at a 9 inch variation at first. But ended up with the cast iron cased 9.9 inch. Which they had never broke in all the testing on the zl1. Hard to beat this setup. That is why i chose this option myself.
smokum is offline   Reply With Quote
Old 05-06-2014, 11:18 PM   #3
James720SS
James720SS's Avatar
Drives: 2010 SS
Has anyone did a ZL1 diff swap with a 4l80e. Would like to know what driveshaft you used.
Polished ECS Novi 1500. Night Fury cam. Alky duel nozzle meth with trunk mount kit. LT Dyntech1 7/8 headers without cats. LPE Twin Fuel Pump. BAER slotted and drilled rotors. BMR rear cradle bushings. Pfadt rear trailing arms. BMR sub frame connectors.Chrome ZL1 Replices front 20x10 rear 20x11 with 275/40/20 Vredestein front 315/35/20 Vredestein rear.720RWHP and 648RWTQ.
James720SS is offline   Reply With Quote
Old 05-07-2014, 09:20 AM   #4
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
I Am Receiving My Zl1 Swap today. I'll let you know how it goes in.
ttshovel is offline   Reply With Quote
Old 05-07-2014, 10:58 AM   #5
moiy1983
moiy1983's Avatar
Yes PLEASE do! Is yours auto or manual?
ProCharger F1-X
ProEFI ECU
Weld Wheels
Old 05-07-2014, 11:50 AM   #6
ttshovel
ttshovel's Avatar
Mine is 6 speed and swapping to 4l80 this winter
Old 05-07-2014, 08:49 PM   #7
BLK1LE
BLK1LE's Avatar
Drives: 2014 Black 1LE SS
What's the price of the complete set up?
BLK1LE is offline   Reply With Quote
Old 05-07-2014, 09:26 PM   #8
CMYarb
CMYarb's Avatar
Drives: 2011 CAMARO SIM 2SS/RS
found this so far
http://www.gmperformancemotor.com/parts/22959394.html
CMYarb is offline   Reply With Quote
Old 05-07-2014, 10:37 PM   #9
ttshovel
ttshovel's Avatar
3700 shipped is what I paid. Got it all on, smooth as glass!
Old 05-07-2014, 10:56 PM   #10
Bo White
Bo White's Avatar
Were did you get yours?
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 05-08-2014, 05:14 AM   #11
ttshovel
ttshovel's Avatar
http://www.superchevyperformance.com...p/22959394.htm
The only thing is the instructions sucked! It was missing a lot off torque specs and it said nothing about a different yoke which was included. You have to use a puller to get it of also. And you have to pull the spindles you can't just swing them out of the way. No modifications needed to fit the diff
Old 05-08-2014, 06:52 PM   #12
moiy1983
moiy1983's Avatar
Has anyone broken anything on this kit or on a ZL1?
ProCharger F1-X
ProEFI ECU
Weld Wheels
Old 05-08-2014, 08:57 PM   #13
pdiddy
Drives: 2011 2SS
I think it's 3700 on parts taxi also I am hoping to get into one of these in the next couple years already have this winters project lined out looking to hear what kind of numbers and abuse these are taking
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
pdiddy is offline   Reply With Quote
Old 05-08-2014, 10:15 PM   #14
smokum
smokum's Avatar
Drives: 2010 2ssrs
I have never saw or heard of anyone busting a carrier or an axle. I know a bunch of guys running these in ss cars and zl1's and some legit 9 second 1000+ rwhp cars without a hickup as of yet.
