![]() Drives: 2013 lt1 camaro Join Date: Apr 2014
v6 engine loud at first start
Hi all,
I am new to this forum I just bought a used 2013 1LT (M6) two weeks ago, love it but when first starting it the engine sounds loud but after 30 seconds it normally goes from about 1200 rpms down to 500 rpms and quiets down. What I need to know is this indicative of the V6 to be so loud (and vibrates) at start-up. Once she is warmed up she sounds normal, my concern is the vibration at startup. Is this typical of this engine. |
Yes this is normal.
B.O.D. 02/16/10
Drives: 2010 SGM Sp. Edition 2017 RS Conver Join Date: Jun 2010
It does that to warm up the catalytic converters.
Thanks guys appreciate the quick replies, sold my 98 Corvette and bought this Camaro, and am not looking back!!!!
Drives: 2019 Dodge Challenger Scat Pack Join Date: Apr 2014
yep! normal! That's when i get most giddy over my exhaust lol
#6 |
![]() ![]() ![]() ![]() Drives: 2014 2SS L99 Join Date: Mar 2014
Does the 2013 you bought happen to already have an aftermarket muffler kit installed?
#7 |
![]() Drives: 2013 1LT/RS Join Date: Jul 2013
Yep, normal for our engines...
#8 |
Do somethin fun every day
Yep, normal for our engines. Enjoy your Camaro and welcome to camaro5.
#9 | |
KaBoom1701
Awesome isn't it? Make you appreciate modern V6 horse power!
Mods:
#10 |
Yes, it is awesome, installed axel back flowmasters yesterday, seems to be smoother at start up. Love. This car!!!
#11 |
![]() Drives: 2015 V6 Silver Ice Metallic Camaro Join Date: Jul 2015
Why it sound loud at cold start and if you attempt after warm up to hold the RPM up to were it goes at cold start the sound is not the same. I have a 2015 V6 Does by any chance the pipe has a flap like the double exhaust?
#12 |
![]() Drives: 2013 Camaro 1LT Join Date: Jun 2015
The cold start is to warm up the cats. It is a very lean setting to build heat quick. Do not touch the throttle during this process. If you do you stop the process and throw the computer in to a limp mode like state for a little while until it figures out what's going on. The reason the 1200-1500 rpm you hear during the cold start sounds different than when you throttle it up to the same rpm is because of the lean fuel trim. No flap.
Elite catch can & clean side oil separator, Apex Scoop, CAI cold air intake, Vmax ported throttle body, TTT ported intake manifold, JacFab intake manifold spacer, Magnaflow cat back exhaust, Weld RT-S 17x5 f and 17x 9 r wheels, MT 28/6/17 f and M&H 275/50/17 r tires, TTT rear seat delete, Nitrous Outlet plate kit, 125hp jets.
#13 |
BCS Auto
Definitely! I got my 2015 1LS as a certified used car, and found out that it's got Flowmaster 409s installed, and man that thing sounds mean during a cold start.
#14 |
Thank you for the quick response. I'm a newbie with Camaro V6. I'm trying to get a better sound but investing little by little. You know how it goes with you still have small kids. So far I have received suggestions like a X-pipe and 2 magnaflow bullet mufflers. I may start with the X-pipe first with stock mufflers and eventually the mufflers.
Thanks again. |
