![]() Drives: 2010 2SS CGM Join Date: Jul 2009
Has anyone noticed any loss of sound quality when using an Ipod? How about with a USB thumb drive? Vs. a CD or XM
![]() Drives: Victory Red 2SS/RS Join Date: Jun 2009
When you use an Ipod the Ipod does the decoding. When you use any other USB device then the vehicle's system does it so there can be a difference. Some have reported that the vehicle's system does a better job then an Ipod. It may also be possible that there could be a difference between different Ipod models but I really don't know if that is true or not as I don't know if they all use the same decoder or is the newer ones are better than the old ones. CD is always going to sound better than MP3s or even XM. The quality difference between XM and an MP3 will depend on the quality of the MP3.
susp.ban4life!
Drives: Raptor Join Date: Jun 2009
My experience is the sound of my MP3 player is far superior to either xm or fm. For what that is worth?
Geek
Drives: IOM 2010 Camaro 2SS Join Date: Oct 2008
In theory, the quality is like this...
CD > iPod/USB > Aux > XM > FM > AM If your mp3s were ripped with a quality encoder (LAME, etc) and at a decent bit rate (192vbr or higher) you shouldn't notice the difference between MP3 and CD. |
aka Patrick
All my music is 192 bitrate so I have no sound/quality issues with my USB drive... sounds just as good as my JL Audio speakers in my truck.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft |
#6 |
More then meets the eye!
I like the sound of the usb, the wife even said that the sound is realy clear.
2010 2SS/RS, M6, OBX 7/8" l/t headers, with high flow cats, MBRP full 3" exhaust, Whipple supercharger, 3.875 pulley, ID-1050X 1260CC injectors, JRE rough idle street blower cam kit, ZL1 fp, ZL1 fpcm, ZR1 3 bar map sensor, cold air intake, Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidamper, MGR shifter, and tune by Jannetty Racing.
#7 | |
![]() Drives: 2016 Camaro 2SS/RS Join Date: Oct 2008
#8 |
![]() Drives: 2010 2SS - IOM, fully loaded Join Date: May 2009
My USB is pretty damn perfect. I encode everything at 320. With the BA sound, there is zero distortion even upwards of 36 on volume. The sound system is really nice.
#9 |
I've tried both USB thumb drive and iPhone and can't tell a difference. My mp3's are encoded at 256-320kbps CBR. Don't listen to a lot of hip-hop or r&b so I may not be the best judge of bass.
#10 |
![]() Drives: Too many to list Join Date: Jun 2009
USB is excellent but only as good as the original recording.
#11 |
![]() ![]() ![]() Drives: Not enough room here! Join Date: Jul 2009
So is a person better off burning CD's or using a player? I was thinking about putting all the music on one player (Zune) so I can transfer between vehicles, am I better off just burning disks? I used the Zune in my Toyota FJ and it seemed like there was a power issue. I would have to turn the volume almost up to the max. At the same volume level a disk would push you out of the truck.
#12 | |
I would use your Zune if I were you. Rip your music high quality unless space is an issue. That way no swapping discs while you're driving. You can change artists or genre's through the head unit. Safer and slicker interface than shuffling discs in your lap.
#13 |
Geek
Agreed. MP3s on a USB device (iPod, USB drive, Zune, etc) are definitely the way to go.
#14 |
![]() Drives: 2010 Camaro 1LT/RS, 6M, IBM Join Date: Jul 2009
Anyone tried connecting an external hard drive through the USB? For example one of those Western Digital 100gig Passport externals which are powered via USB?
| iPod touch / v3.0 upgrade | all5ofus | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 6 | 07-11-2009 08:55 PM |
