Old 07-17-2014, 06:21 PM   #1
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
Axle seals
Rear end chattering, 2600 mile SS common problem. I know this requires a rear end fluid change with friction modifier, I know how a limited slip differential works.
So I decided to let the dealer take care of it..... see above 2600 miles.
What the purpose of replacing the axle seals as well? I had them show me the service bulletin it says right there to change the axle seals and put different fluid in the differential. So that's what they want to do, probably next week when the axle seals come in. Well that's kind of a big job for just a fluid change, it kind of worries me.
If I don't let them do it, any future problems won't be covered under the drivetrain warranty. If I do let them do it, they make screw it up.
No dog in this fight anymore.
5th Gen owner 2009-2016.
two_wheel_mayhem is offline   Reply With Quote
Old 07-18-2014, 07:46 AM   #2
GFORCE1320
Drives: 05 GTO
The axle seals are prone to leaking, maybe the newer ones are better quality.
GFORCE1320 is offline   Reply With Quote
Old 07-18-2014, 11:47 AM   #3
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
What usually happens is when the axle is being removed the snap ring groove of the inner CV will catch the seal and pull the inner spring out. just be careful.
Driveshaftshop is offline   Reply With Quote
Old 07-18-2014, 05:56 PM   #4
two_wheel_mayhem
Ok I haven't spent enough time around these cars. Explain why you have to remove axles to change the fluid.
BTW I have installed tons of front wheel drive half shafts.
Old 07-18-2014, 05:58 PM   #5
two_wheel_mayhem
The service bulletin is for all '10-'14 Camaros with Limited Slip diff except ZL1 that have a customer complaint about low speed chattering around corners.
Old 07-19-2014, 06:28 PM   #6
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
FWIW, I was told the old seals are not compatible with the new diff fluid.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 07-20-2014, 08:47 AM   #7
two_wheel_mayhem
Well that has to be their logic I guess.
