Old 07-18-2014, 06:13 PM   #1
Rico
Flying da helicopter
Rico's Avatar
Drives: Black SS/RS
Dyno-is this right?
I just installed my SLP supercharger with 3.4" pulley. It is producing about 10 psi with this setup. My supporting mods are livernois stage II cam, CAI intake, ported throttle body, kooks long tube headers, borla ATAK and high flow cats. The dyno shows 615 rwhp/565 tq. Does this sound low or is this about right? Thanks
BTW, it's fun as hell to drive!!!
Rico is offline   Reply With Quote
Old 07-18-2014, 06:27 PM   #2
jon6.0
Going for Plaid
jon6.0's Avatar
Drives: 2011 C6
Can't get the complete story just from this. High temp and lots of humidity. Did your tuner say how much timing they were able to get into it? Is this a ZL1? This might be in the wrong section too.
2014 ZL1, manual trans, carbon hood insert, Rotofab, Pacesetter 1 7/8" headers, 1" drop BMR springs, stock pulleys, 91 octane tune, 545rwhp & 515rwtq
Serviced and modded by Cordes Performance.
2011 C6, 750rwhp, forged LS3, ported LSA heads, Vortech Ti-trim, 227/243 115+4 Lunati cam, ported LS3 intake, Alky Control methanol, Pfadt sways/shocks/trans mounts, Pfadt tri-y headers(Sold 6/28/14)
jon6.0 is offline   Reply With Quote
Old 07-18-2014, 06:29 PM   #3
Rico
Rico's Avatar
Drives: Black SS/RS
It probably is the wrong section....I can never get it right. It's an SS with SLP supercharger. He said it was about 102 degrees outside so that May have contributed. Not sure on the timing though.
Old 07-18-2014, 06:42 PM   #4
jon6.0
Going for Plaid
jon6.0's Avatar
Drives: 2011 C6
I would be happy with it. It's probably pulling timing for IAT's and heat soaked. Dyno it again in the winter or add a meth kit.
Old 07-18-2014, 06:45 PM   #5
Mikes fast ss
Slowhawk Built
Mikes fast ss's Avatar
Drives: 2010 Supercharged SS
Seems right. The numbers are a little low but with 102 temps I would expect that.
9.21 @ 149 Slowhawk Performance
Mikes fast ss is offline   Reply With Quote
Old 07-18-2014, 06:52 PM   #6
Rico
Rico's Avatar
Drives: Black SS/RS
If I get a tune in the winter, won't it run a little rich when it's hotter outside? Thanks for the advice, I'm considering getting a meth kit. Jannetty racing has one that goes in the trunk so that looks good to me.
Old 07-18-2014, 06:57 PM   #7
Mikes fast ss
Slowhawk Built
You do not want that meth kit. Get an Alky Control kit. They have a 4 gal trunk take as well. Its not so much as the heat. The heat is pulling the timing. If you got tuned in the winter the ECM would still pull timing when it gets hot. You are on the right path with the meth. You need to control the heat.
Old 07-18-2014, 07:06 PM   #8
jon6.0
Going for Plaid
jon6.0's Avatar
Drives: 2011 C6
Alky Control or nothing for meth kit. Their pump is rated for 100% meth and all braided lines. It's a little more spendy, but worth it. You will just pick power up once it gets cold.
Old 07-18-2014, 07:10 PM   #9
Mikes fast ss
Slowhawk Built
Excellent point. The one the shop that you mentioned sells won't do 100% meth.
Old 07-18-2014, 07:14 PM   #10
jon6.0
Going for Plaid
jon6.0's Avatar
Drives: 2011 C6
Another thing that most won't do is pull and inspect/rebuild their meth pump yearly. You could even buy an extra pump and just swap them out yearly and send the other pump to Julio for inspection/rebuild. Not a bad idea if you are meth dependent. The above combo wouldn't be meth dependent though.
Old 07-18-2014, 07:29 PM   #11
Rico
Rico's Avatar
Drives: Black SS/RS
Would a 50/50 kit be good as well? I've read about people having problems with the meth eating through the rotors of the supercharger. Not quite sure since I'm new to that. Thanks again for the advice, you guys are great.
Old 07-18-2014, 07:31 PM   #12
Mikes fast ss
Slowhawk Built
Those are two completely different debates. Go with what your tuner is comfortable with. Is Corey tuning your car? I see the dyno sheet is from Henderson.
Old 07-18-2014, 07:32 PM   #13
Rico
Rico's Avatar
Drives: Black SS/RS
Yah Corey is tuning it
Old 07-18-2014, 07:34 PM   #14
Mikes fast ss
Slowhawk Built
Talk to him, let him decide what's best for your car. Case closed
