Old 07-27-2014, 08:30 PM   #1
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
Boston Acoustics wiring diagram
Either I am a complete dumbass or I'm blind, but I cannot find a wiring diagram for the stock Boston Acoustics amp.
I am doing a complete rebuild of my stereo system (only thing I'm keeping is the factory head unit). Because of the build I have going, I don't need the RCA outputs from the ******** FARK harness. I have no intention of going back to the factory setup because the stock speakers are gone, so I dont care about losing the stock harnesses.
That's not to say that using the stock harnesses won't be helpful with figuring out which wires go where...
Any help would be appreciated.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 07-27-2014, 09:24 PM   #2
darkrider01
Aural Assault Vehicle
darkrider01's Avatar
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali
This should be what you are looking for. Download the zip file in this post and it should have everything you need.
http://www.camaro5.com/forums/showpo...0&postcount=62
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Exterior Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber * OEM body kit Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Mosconi 6to8v8 w/ RCD * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692
darkrider01 is offline   Reply With Quote
Old 07-27-2014, 09:56 PM   #3
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Perfect, thanks!!
