Old 07-29-2014, 12:47 PM   #1
stoopid
Drives: 4 wheels
Upgrade just the speakers (base system)
Let me first say, the stock stereo is okay. Have had better/worse.
My primary complaint: The tweeters are a little harsh, but I also don't know if it isn't just the signal sent by the head unit (tried EQ'ing it away, and it sounds like a spike/coloration around 10khz so it's unavoidable at louder volumes unless I strip all the treble).
Assuming it's not the signal coming out of the head unit, what are my easier upgrade options? Just get new front components and 6.5" rears? Skip the rears and just get components?
Hypothetically, if I went to a custom car stereo shop and gutted everything, got a new head, sub, amps, speakers, etc -- what functionality do I lose with th new head unit that the current one provides? [most of my climate controls, for example, show on the display on the stereo]
Just looking to bounce around ideas. I plan on having this car for a while and upgrading the stereo is one thing I'm not shy about since I'm a musician and enjoy my tunes.
stoopid is offline   Reply With Quote
Old 07-29-2014, 02:09 PM   #2
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
You can keep the stock HU if you install something like this:
http://www.pacificstereo.com/audiocontrol-lc7i.html
It may help with the stock speakers too.
Just my $0.02
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 07-30-2014, 06:39 AM   #3
jiannotto9492
Drives: 2014 Red 2LS
You're looking at voiding a warranty and possibly losing climate control. Your best bet would be to have the dealer upgrade your sound system to the BA one. I honestly just tapped into the rear deck speakers and tossed a set of 10" subwoofers in my trunk and the sound sounds so much better.
jiannotto9492 is offline   Reply With Quote
Old 07-30-2014, 09:22 AM   #4
Texzen
Texzen's Avatar
Drives: 2013 SW 2SS/RS/1LE
Just my $0.02
Not sure this will help with stock speakers, but my understanding is that in the non boston acoustic systems, the signal coming out of the the head unit is pre-equalized for the speakers/car in general. Adding different speakers will have, at best, unpredictable and probably unpleasant results.
You'll definitely want to either get a line out converter & amp combo that does signal summing so you have a flat/unequalized signal to work with or go the full head unit (and speaker) replacement route. Scosche (http://www.scosche.com/2010-up-chevr...stallation-kit) and Metra (http://www.metraonline.com/part/99-3010S-LC++++) make kits that retain the AC functionality, etc... I'm pretty sure if you buy the replacement head unit from Crutchfield they'll give you 1/2 off of either of these kits.
Good luck w/the search/project!
Texzen is offline   Reply With Quote
Old 07-30-2014, 11:48 AM   #5
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
I've read this quite a few times but from reading people's install reviews and asking around, it seems not very many people dislike the results. Any opinions why that is? What amplifiers flatten out the signal?
Old 07-30-2014, 12:48 PM   #6
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
I don't understand this post. Tex says the LC7i won't help, but then says the OP needs a signal summer. The LC7i is a signal summing device. It's designed specifically for this to "clean up" the signal from the factory HU before sending it off to either the speakers or amplifier(s). The LC7i also has controls to adjust the outputs for channels 1&2 (fronts), 3&4 (rears), and 5&6 (subs).
You will definitely need one if you go with aftermarket speakers.
Old 07-30-2014, 01:14 PM   #7
Texzen
Texzen's Avatar
For the record, it was not my intent to say the LC7i wouldn't help. If it sums the signals and provides a flat(er) curve to deal with you should be good to go.
Old 07-30-2014, 01:48 PM   #8
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
No worries, just confused.
Old 07-30-2014, 01:53 PM   #9
Texzen
Texzen's Avatar
I seem to walk around in a state of perpetual confusion.
As an fyi, I lived in Colorado Springs from 2003-2006. I spent quite a bit of time in & around Castle Rock & Castle Pines. Love it up there.
Old 07-30-2014, 02:47 PM   #10
darkrider01
Aural Assault Vehicle
darkrider01's Avatar
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali
It does NOT provide a flatter curve. All the LC7i does is summing and a powered LOC.
I believe that the cheapest option would be something like a JL Audio Cleansweep. Then you have the Alpine IMPRINT system, the JBL MS8, Rockford Fosgate 3Sixty.3, and the list goes on. If you have the Boston system, the EQ in the stock head unit should be flat, in which case the best start would be replacing the factory amplifier.
That make sense?
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Exterior Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber * OEM body kit Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Mosconi 6to8v8 w/ RCD * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692
darkrider01 is offline   Reply With Quote
Old 07-30-2014, 02:58 PM   #11
stoopid
Drives: 4 wheels
That make sense?
I believe it does!
Thanks all for the replies. I'm going to look into some of the options mentioned and see what fits the budget, etc.
Old 08-01-2014, 09:22 AM   #12
stoopid
Drives: 4 wheels
So after thinking about it, checking out the pricing for a full upgrade, this appears to be the most cost effective option. Getting the BA system from the dealer would be second best (would likely be sufficient for me).
Old 08-03-2014, 12:00 PM   #13
lscamaro
lscamaro's Avatar
Don't get the ba system. It won't work. The wiring and everything is completely different so when it would all be said and done, it'd be the most expensive option
Old 08-04-2014, 09:25 AM   #14
stoopid
Drives: 4 wheels
Any suggestions/caution regarding sub box designs? I use my trunk so taking up the least amount of space as possible is best. Might go to a local audio shop to see what they offer. They may have even done a Camaro recently (it's a popular car around here).
I see the ******** is popular and it looks like a good design (how does it stay in place?):
http://********.com/product_info.php...&products_id=7
Is there anywhere in the back of the car (maybe under the rear seats) a sub could fit? I don't even care if it's just an 8", just looking for more low end. Don't need to rattle windows.
