Old 09-02-2014, 11:06 PM   #1
AF1Strider
AF1Strider's Avatar
Drives: 2011 Camaro 1SS/RS
SCT TUNER
Hey guys I've done some research about the SCT TUNER, but I couldn't find any information on torque management. I was wondering if anyone knows if it can turn off torque management on a LS3 6spd car? I'm thinking of purchasing one but want to make sure that it turns off the torque management. Thanks for the help guys!
AF1Strider is offline   Reply With Quote
Old 09-02-2014, 11:36 PM   #2
62nalide
62nalide's Avatar
Drives: 2013 SS
HP Tuners and or EFILIVE is they RIGHT way to tune these cars
62nalide is offline   Reply With Quote
Old 09-03-2014, 12:37 AM   #3
nivensid
nivensid's Avatar
Drives: 2010 Camaro SS 6 speed
I don't think he asked for your opinion about you feel is the RIGHT way to tune these cars.
Some people like to stand out in the crowd to be noticed......I like to stand back in the crowd and notice people....
2010 Camaro SS LS3
SW performance Headers, SW Retro Chambered Catback, High Flow Cats, K@N CAI, Apex Catch Can, Vmax Ported Throttle Body, Hurst Short Throw Shifter, 3.91 Gears, JRE Tune and adding to the list..
nivensid is offline   Reply With Quote
Old 09-03-2014, 12:47 AM   #4
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
so whats your two cents then?....Did you just post to straighten him out?
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 09-03-2014, 01:11 AM   #5
62nalide
62nalide's Avatar
Drives: 2013 SS
, 1st sentence says he's done research. I mentioned what 90% of the LS tuning world uses to tune. More research never hurts.
Old 09-03-2014, 03:32 AM   #6
AF1Strider
AF1Strider's Avatar
I would eventually be getting a dyno tune, just for now I was looking into a handheld tuner until I get some more bolt ons. I know dyno tuning is the best way to optimize my performance. Just not sure if it's worth it now and then again when I get long tubes and such.
Old 09-03-2014, 04:37 AM   #7
Cyber Gray
Wind Rider
Cyber Gray's Avatar
Drives: ZL1 19 White; Jeep 5.7 GC 15
I have the SCT X4, they dont work this way. You buy the device empty and you need to add a custom tune that will enable you to control some the car functions.
You cant control it manually as you like. The tuner will do it for you.
I guess that Hypertech and Diablo offer what you want.
Im not Gray any more !!
Cyber Gray is offline   Reply With Quote
Old 09-03-2014, 07:02 AM   #8
nyny69
Drives: 2010 IOM SS
Sorry. This is wrong. The SCT does have adjustable parameters. Not much but it does. These features are locked out from some tuners. They even sell a SCT that comes with 3 preloaded tunes.
But I have to agree with 62 on this. HPT and EFI Live are better options. You are not held to the few that use SCT and for basically the same money you have so many more options.
Take HPT for example, while you have full control over your cars parameters it doesn't stop you from getting a remote tune. Any tuner can email you a file for it
nyny69 is offline   Reply With Quote
Old 09-03-2014, 10:14 AM   #9
Cyber Gray
Wind Rider
Cyber Gray's Avatar
Then mine was locked because it was completely empty. The adjustable parameters appeared only after I received the custom tune !!
Old 09-03-2014, 11:06 AM   #10
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
To use SCT for tuning those parameters, you'll need to purchase Advantage 3 or Pro Racer Tuning software along with the hardware and cables required. I don't know much about SCT, but if you do not already have this setup you might as well look into EFI or HPTUNERS. Very easy to remove torque management with HPTUNERS. I've done it myself. Your other option is to have a tuner remove it for you, but that might make your SCT handheld useless afterwards if the tuner doesn't use the SCT tuning software.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 09-03-2014, 06:14 PM   #11
CrystalRedTintcoat
CrystalRedTintcoat's Avatar
Drives: 2013 2SS 1LE NPP GBE
Just bough and SCT X4 from JRE. Call Ted Jannetty and he can answer your question.
-CRT
Sent from my iPad using Tapatalk
2013 1LE NPP GBE
Mods
Track Days
CrystalRedTintcoat is offline   Reply With Quote
Old 09-03-2014, 06:24 PM   #12
AF1Strider
AF1Strider's Avatar
Well it seems like ordering a SCT handheld would just be a waste. I'll wait until I get Long Tube Headers installed and head up to Southwest speed, his shop is about 15 minutes away from my house, for a dyno tune. Thanks for the information and opinions I really appreciate it.
Old 09-03-2014, 06:24 PM   #13
Johnthegreat
Johnthegreat's Avatar
Drives: 2012 2SS/RS black camaro
I have sct and love it. It has options for just about everything including long tubes headers. It docent have torq manegment but it has everything else.I love it woke the car up
Johnthegreat is offline   Reply With Quote
Old 09-03-2014, 06:40 PM   #14
1KillerSS
1KillerSS's Avatar
Good luck and have fun!
Build thread
