09-16-2014, 08:53 PM | #1 |
Drives: Camaro LS Join Date: Dec 2012
OFFICIAL 2010+ Chevy Camaro Light Bulb Size Guide
2010-2013 Camaro RS Headlights Photo credit hidlightreviews.com Headlight (High and Low beam) H13 or 9008 Headlight with Factory HID D1S Fog Light 5202 or P13W (RS trim) Front Turn Signal bulb 3157A License Plate bulb Back Up Light 5008 Brake Light bulb 3157 Tail Light Bulb 3157 2014+ Camaro photo via CarandDriver.com Headlight Low Beam H11 Headlight High Beam H9 (Ive used H11 in its place with slight trimming) Headlight with Factory HIDs D3S Headlight Z28 H13 or 9008 Fog Light P13W or PSX26W Front Park and Turn Signal Lamp (Except ZL1 and Z28) T20 or 7550 Front Park and Turn Signal Lamp (ZL1 and Z28) 3457NA License Plate bulb W5WLL Rear Stop Light T20 or 7440 Rear Tail Light 7444LL Rear Turn Signal Light W21 |
09-16-2014, 10:52 PM | #2 |
Drives: 2011 IOM Camaro Join Date: Jul 2010
Great post!! Nice and concise info! A couple of things to add:
the license plate bulb for 2010-13 is 194 (same as W5W, or T10 if going with LED's). The ZL1 fog lights are H11. Also for 10-13 (and probably '14+), the side marker lights are 194. The dome light and trunk light are also 194. As for the DRL light bulbs (the "fog" lights on the RS), it's P13W for 2010 and 2011, then was switched to PSX26W for the 2012-2013 model. To make things more confusing, some 2012's (I'm assuming early 2012 Camaros) use the P13W bulbs instead... So 2010, 2011, and early 2012 use P13W, and mid 2012 and 2013 use PSX26W. |
10-09-2016, 01:45 PM | #3 |
Drives: 2012 chevrolet camaro 2ss Join Date: Sep 2016
Whats the headlight bulb for 2012 camaro ss
10-10-2016, 03:07 PM | #4 | |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
10-10-2016, 06:38 PM | #5 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
I guess nobody reads their manuals.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
12-07-2016, 01:57 PM | #6 |
Drives: 2014 Camaro SS Join Date: Nov 2016
Funny, digital copy of the 2014 camaro ss' owners manual only lists the licence plate bulb and the replacement procedures... No other light on the car... Seems they want you to take it to the dealership to replace the bulbs...
Sent from my SM-G935F using Tapatalk |
12-27-2016, 05:29 AM | #7 |
Drives: 2010 Camaro SS, 1998 Trans Am Join Date: Feb 2016
Here's an updated list from http://www.modifiedlife.com/2010-che...size-diagram/:
Low Beam Headlamp Light Bulb Size:H13 (9008) High Beam Headlamp Light Bulb Size:H13 (9008) Parking Light Bulb Size:3457A Front Turn Signal Light Bulb Size:3457A Rear Turn Signal Light Bulb Size:3157 Tail Light Bulb Size:3157 Stop Light Bulb Size:3157 High Mount Stop Light Bulb Size: LED Fog/Driving Light Bulb Size:5202 License Plate Light Bulb Size:2825 Back Up Light Bulb Size: 5008 Front Side Marker Light Bulb Size:194 Rear Side Marker Light Bulb Size:194 or 2825 Trunk/Cargo Area Light Bulb Size:175
2010 Camaro 2SS
1998 Trans Am Last edited by joeyofblades; 12-29-2016 at 03:52 PM. |
12-29-2016, 03:49 PM | #8 | |
12-29-2016, 03:52 PM | #9 |
5008 for reverse bulbs - found this by googling so not 100% sure
2010 Camaro 2SS
1998 Trans Am |
Tags |
camaro lights, headlight bulb, hid lights, light bulbs |
