Old 10-14-2014, 05:31 PM   #1
Brownster
Drives: 1966 GTO Convertible/ZL1 Vert
Going Catless
Tried to research this to no avail.
To all you people who go catless, how does your car pass inspection?
Thanks!
Brownster is offline   Reply With Quote
Old 10-14-2014, 06:21 PM   #2
hognutz
hognutz's Avatar
Drives: 2013 ZL1
mine passed because there is no inspection.
how I would pass is get my inpsection with cats and then swap them out after that.
how frequent are your inpsections?
2016 2SS
2020 super duty on 37's
hognutz is offline   Reply With Quote
Old 10-14-2014, 06:27 PM   #3
Brownster
Once a year.
Old 10-14-2014, 06:43 PM   #4
revobasher
revobasher's Avatar
Drives: 2013 ZL1
Going Catless
Is catless quite a bit louder? Any perf gains?
2013 ZL1 - Blue Ray Metallic
JDP 850 Package
740hp/700tq @14lbs on E85
Build Thread
revobasher is offline   Reply With Quote
Old 10-14-2014, 08:12 PM   #5
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
If you have headers it will be louder. No headers cat delete will be louder but I do not know how much because I installed headers and pulled the cats off at the same time. Performance gaines I doubt much if any.
Bigtime53 is offline   Reply With Quote
Old 10-14-2014, 08:18 PM   #6
hognutz
hognutz's Avatar
Drives: 2013 ZL1
1. it a decent amount louder.
2. proabably ~4hp
3. a cat that is not there can not fail.
2016 2SS
Old 10-14-2014, 08:30 PM   #7
Modern07
Mid-Florida Camaro Club
Modern07's Avatar
Drives: 2019 ZL1 on Order
With headers yes
I'm actually about to put solo resonators on mine because it's stupid loud.
(Headers, Catless, Corsa Exhaust)
Modern07 is offline   Reply With Quote
Old 10-14-2014, 08:36 PM   #8
hognutz
hognutz's Avatar
Drives: 2013 ZL1
Originally Posted by Modern07 View Post
With headers yes
there are also some muffled xpipes from magnaflow or dynomax I think you could try as well. we did one of these on my dad's 502. it will knock down the volume.
if you keep the stock catack you can just wire the flaps closed at all times and really knocks it down to extremely livable. proabably a tad quiter than cat's on with stock flap control.
2016 2SS
Old 10-14-2014, 11:05 PM   #9
revobasher
revobasher's Avatar
Drives: 2013 ZL1
Thx. I will have the kooks headers but stock exhaust. Plan for now is to keep the cats. I can't justify replacing the exhaust either. Unless it's restrictive. It just sounds great. Now with that said, I am installing the JDP 850 package here soon.
JDP 850 Package
Build Thread
Old 10-14-2014, 11:22 PM   #10
hognutz
hognutz's Avatar
Drives: 2013 ZL1
don't run cat's you just burn them up if you drive the car hard. you don't need to replace the stock exhaust. worst case is just apply 12v at all times to the controller and close the flapps if it is too loud.
2016 2SS
Old 10-14-2014, 11:50 PM   #11
revobasher
revobasher's Avatar
Drives: 2013 ZL1
Cool thx
JDP 850 Package
Build Thread
Old 10-15-2014, 07:56 AM   #12
Whos_Drivin
Drives: '12 Camaro ZL1, '16 Silverado Z71
There's a thread in the DIY section to wire in a 3 way switch for this. Hardest part is figuring out where to put the switch. I have mine setup to be all open, factory, or all closed. Pisses off the neighbors a little less now.
Whos_Drivin is offline   Reply With Quote
Old 10-15-2014, 09:19 AM   #13
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I am still just using my $15 remote relay I bought off amazon to control it. I no longer desire to have "open" at all times so I just have stock and always closed.
I have been thinking about switching it to a 3 position switch in the console. all you have to do is tap into the ground wire for the exhaust relay and have normal, broken connection, strait to ground.
2016 2SS
Old 10-15-2014, 09:29 AM   #14
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
I just went catless last week with the installing of jba mid pipes. Enclosed is a dyno vid with factory exhaust baffle fuse pulled after the install along with upper pulley, injectors, snout & blower porting.
I have driven the car wiht the fuse back in since these mods and mid range torque is dramatically reduced. Just seat of the pants observation. I like both versions however. Very mild to WILD combo now.
15' Ashen Gray Metallic Z/28
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH
12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD
06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD.
96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH
2NASSTY is offline   Reply With Quote
