![]() Drives: 2010 Camaro 2SS/RS M6 Rally Yellow Join Date: Sep 2008
Mishimoto Oil Cooler Request
This past spring I purchased a universal oil cooler kit from Mishimoto. To make a long story short it didn't fit. I Recently wrote to the company about my issue and I told them that they should consider making a direct fit Oil Cooler Kit because of the number of people that would consider buying this because of the large amount of people who track their car and all say how the factory oil cooler doesn't cool the oil fast enough. I also told him that there aren't many companies that make oil coolers specifically for our cars. I received an email back from them within a day and they said if I can get a list of people that would be interested in this oil cooler kit and the demand is out there they may design a kit that would fit our cars in the near future. So if you are not familiar with Mishimoto products go to their website www.mishimoto.com to check out their products. If anyone is interested in trying to get this ball rolling please post up in this thread.
Thanks |
KaBoom1701
If this will fit a V6 also then I'm in as well.
Mods:
When is enough ever...
Drives: 2006 Silverado 2500HD CC/SB LBZ Join Date: Apr 2011
Location: Residence: Chula Vista, CA Home: Billings, MT
Interested.
The Project: 2011 Camaro 2SS/RS (ERL 427 Superdeck NA Monster)
"Just like farmer engineering. Find the weak link and fix it, then find the next one." Salt Cat Racing |
![]() Drives: 2013 ZL1 M6 Join Date: Jan 2014
I'm interested for my ZL1 and I do track it. Mishimoto will have to come up with different cooling kits for different Camaros. The radiators are different for the SS, ZL1 and Z28, so the stock factory oil cooler routing is probably different as well.
Corvette Z06/Z07/M7 (2016) Late Model Racecraft Intercooler reservoir and 160* Thermostat.
Sold- 2013 Camaro ZL1 M6 (Black on Black), Detroit Speed Sway bars, DOT 4 Brake Fluid, separate clutch master reservoir, Moroso Catch Can. 2.11 at Thunderhill 100* ambient. Ron Davis Radiator and AFCO Heat Exchanger installed after track day, Roto-Fab CAI. Sold- 2001 Mustang Cobra -Griggs GR40,M5, Torsen T2-R, 4.10, 14" Brembo fronts, high 1:40s at Laguna Seca |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: cars Join Date: May 2011
You were expecting a universal part to be direct fit? Everyone with an aftermarket oil cooler is using universal coolers.
#6 |
The problem was the sandwich plate and adapter not fitting. It wasn't the oil cooler itself.
#7 |
Are you trying to keep the stock cooler/heater? Just get the improved racing thermostat adapter and you're done. Haven't noticed any appreciable difference in warmup time without it.
#8 |
mishi makes good stuff. id probably be down for one if they made one.
#9 | |
If you are talking about the oil temp and you haven't added your own oil temp sensor somewhere you won't see a difference. Our oil temp isn't actually the "real" temp. It's just an estimate based off of a few factors. |
#10 |
im curious as i have read that a few times as well. is there a way to add that temp sensor and wire it in to the OE oil temp gauge so it reads actual temp?
#11 |
![]() Drives: 2014 2SS 1LE Join Date: Sep 2013
I'm interested
14 2SS RS 1LE Recaro NPP Pat G cam and tune, Trick flow heads Long tube headers catless
#12 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
I would have interest.
The factory oil cooler is a POS and mine cracked when drag racing. My replacement one (under warranty) is LEAKING.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
#13 | |
I wish I knew. I wonder if any shops can chime in with experience on this. |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Evil Eva, 2010 2SS LS3 Join Date: Aug 2013
I would probably be interested.
Does this increase the oil capacity beyond the standard 8 quarts? Does anyone have a basic SWAG on the install time?
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
