Old 11-13-2014, 09:44 AM   #1
Garrett Custom
Garrett Custom's Avatar
Drives: 2012 Camaro ZL1, 2000 Silverado LT
Battery Tender
Has anyone installed a battery tender? I'm just seeing if anyone has done this. With the battery being the trunk, I don't want to have to leave the trunk open, I would prefer to hook the lead up under the hood.
Thanks
v/r
Roger
2012 ZL-1 #1076
2016 Explorer XLT (wife's)
2002 Ducati ST4S
2000 Silverado LT
1995 Triumph Daytona 1200
Garrett Custom is offline   Reply With Quote
Old 11-13-2014, 10:02 AM   #2
Blk-Ice
750HP of Twisted Reaper!
Blk-Ice's Avatar
Drives: Blk 2SS/Blk Carb Fibr NS-1 stripes
I have.....there is a rubber plug on the right side near the battery that pulls out and you feed the lead through that hole and i have a quick connect that attaches to the battery.
Fear the LMR Twisted Reaper Brotherhood!
Blk-Ice is offline   Reply With Quote
Old 11-13-2014, 10:31 AM   #3
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Thanks
You can connect it under the hood to the "remote" battery terminals, that's what they're there for and what I use for my tender. Check your owners manual for their location...can't miss em.
camguynj is online now   Reply With Quote
Old 11-13-2014, 11:30 AM   #4
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
Just slit the plug, pull the wires in and RTV the plug and you are good to go. I use the Tender Jr.
MMC is offline   Reply With Quote
Old 11-13-2014, 11:38 AM   #5
HDRDTD
I leave the tender outside the car. It has long leads that go to extender leads and I connect those directly to the battery in the trunk. The leads are small enough not to damage the rubber trunk seals.
Old 11-13-2014, 11:41 AM   #6
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
+1
that's the way my Ctek works..
ZMEnow is offline   Reply With Quote
Old 11-13-2014, 02:21 PM   #7
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
I use a Battery Sentinel true float trickle charger during winter storage. I popped the insulator off the POS lug under the hood and drilled a hole in the lug terminal to attach a #6 screw and mounted the ring terminal of the POS charger cable to this and put the NEG terminal under the grounding post beside it. Then popped the insulator back on. This setup has a quick disconnect that connects to the charger. In summer I just pull the disconnect and tie wrap the short piece mounted to the lugs to the underside of the battery cable out of sight.
Old 11-13-2014, 03:49 PM   #8
hotlap
hotlap's Avatar
Drives: 20 1LE 2SS M6 Rally Green
I connected under the hood to the remote terminals too. Easy
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.”
Ronald Reagan -
hotlap is offline   Reply With Quote
Old 11-13-2014, 04:12 PM   #9
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
I have the ringed terminal connected to the red accessory post, and the tender plugged outside. Its a great aid to a hibernating car.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
'25 Silverado 1500 High Country 6.2L
lbls1 is offline   Reply With Quote
Old 11-13-2014, 07:37 PM   #10
DrkPhx
DrkPhx's Avatar
Same here. I use the Ctek charger with the extended terminals for Winter storage. You can run it through the lower grill up to the terminals if you want or with the hood open. Either way works fine. Great charger by the way.
Old 11-14-2014, 03:49 AM   #11
ZL155
Banned
Drives: 13' ZL1
Or you can just disconnect the positive cable and not worry about a battery tender..
Do it every year, works like a charm.
Sent from my SM-N900V using Tapatalk
ZL155 is offline   Reply With Quote
Old 11-14-2014, 07:34 AM   #12
mrshanes
Drives: 2014 Camaro ZL1
How long have you been doing this and how long is your storage period? I would think the battery will drain some, but still have enough to start the engine when you get it out of storage. While this seems OK, I would think it affects the overall life of the battery. How many years do you get out of your batteries?
mrshanes is offline   Reply With Quote
Old 11-14-2014, 12:14 PM   #13
ZL155
Banned
Drives: 13' ZL1
It doesn't effect anything. I do it with my 8+ old battery in my tractor as well. I did have to finally change that one but That's after 8 years of disconnecting it through the winter.
Battery doesn't drain any if not hooked up. Does your Duracells sitting in the drawer drain when not in use? Nope!
Old 11-14-2014, 12:16 PM   #14
ZL155
Banned
Drives: 13' ZL1
Storage period is 5 to 6 months and been doing this for 20 or so years with different cars throughout, cause I'm always changing cars every couple years.... never once had a problem
This car I'm keeping though! Awesome.
