Old 08-21-2009, 10:20 AM   #1
King Mouse
King Mouse's Avatar
Drives: EXT
IOM Question for Painters
Does anybody happen to know what color primer/sealer should go under IOM to get the correct color?
Please don't post if you DON'T know.
Thanks
King Mouse is offline   Reply With Quote
Old 08-21-2009, 08:55 PM   #2
slacker
Troubled 40 something
slacker's Avatar
Drives: 2010 IOM RS/SS M6
Thanks
I can tell you from experience (I was a painter for 10 years before I do what I do now) - the best color to use under red is white/very light grey sealer, so I would assume the same would be true for orange. Most red's are semi-opaque, and dark colored sealers give a dark cast to the final color. That is, unless you load the thing with 10 coats of base (which shouldn't be necessary). If you use red oxide, double the amount of color coats you expect you will need.
So in short- use the lightest colored sealer you can get.
http://www.camaro5.com/forums/image.php?type=sigpic&userid=8680&dateline=1260288  130
slacker is offline   Reply With Quote
Old 08-22-2009, 12:03 AM   #3
King Mouse
King Mouse's Avatar
Drives: EXT
Slacker,
Thanks! I figured a white sealer but wasn't too sure. Some of the exposed places on my car look as though there is a black base.
Old 08-22-2009, 08:50 AM   #4
slacker
slacker's Avatar
You could do a spray out if you are trying to make sure you get a 100% match- all paint stores sell these cards with half black/half white face and a hole in the middle. You spray as many coats as it takes to cover, then you compare to your car. I had a whole set of spray out cards for the vehicles I painted (first Lincolns, then Honda/Mitsu).
Do the IOM with IOM interior have IOM door panel inserts, and dash trim? dragonZ28 5th Gen Camaro SS LS LT General Discussions 14 11-12-2009 10:22 PM
IOM SS owners.... TJ91 Canada 25 06-09-2009 02:42 AM
Is the IOM interior on the IOM exterior overkill? Ant Cosmetics and Lighting Modification Discussions 28 04-27-2009 02:06 PM
3 Camaro's: Including the IOM / IOM SS RS Combo duffmobile Camaro Photos | Spyshots | Video | Media Gallery 12 04-19-2009 02:54 PM
Your vote will help greatly--CGM with IOM interior cerberus 5th Gen Camaro SS LS LT General Discussions 21 04-17-2009 07:36 AM
