Old 08-22-2009, 03:56 PM   #1
alexice1421
alexice1421's Avatar
Drives: 2012 Chevy Corvette TR 2LT LS3 6spd
Camaro RS HID Bulb Size
Just wondering what the bulb size on the camaros with the RS package... and also what the rating of the HID's are?
The bulb sizes are different from stock headlamps so thats y im asking.
I'm hoping its D2S lol i just keep lookin everywhere for this...and no one knows and i'm hoping you guys can help me out...thanx
alexice1421 is offline   Reply With Quote
Old 08-22-2009, 04:36 PM   #2
camaro104
camaro104's Avatar
Drives: 2017 Nightfall 50th Annivers Camaro
Send a message via AIM to camaro104
check this place out, they can tell you all you need to know....They helped me out.
http://www.turnagainhighlights.com/
camaro104 is offline   Reply With Quote
Old 08-22-2009, 07:46 PM   #3
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
WELL the problem is that he was looking for the FACTORY bulbs, Turnagainlights sells a KIT for converting from standard lights to HIDS, I would certinly ask if THEIR lights are the same as factory HID bulbs. If you look in the Camaros manual, they are NOT listed and points you to your dealer, as they do not recommend you or anyone changing them out, insted a certified tech to do it. The reason why is the fact that there is a lot of stored "juice" in the capacitors and you could be easlily get a very bad shock or even get electrocuted if attempted.
Old 08-22-2009, 10:58 PM   #4
alexice1421
yea thats a conversion kit for someone who has the stock halogen headlamps.
I tried calling the dealer and they beat around the bush way too much
the real reason i have this question is i have a set of d2s bulbs 12000k and i want to know if i can use them with my camaro when it comes in...cuz if not i wanna sell them
Old 08-27-2009, 01:27 PM   #5
sales@spencershids.com
Drives: 2008 silverado, 2006 Impala
I'm pretty sure they'll work. If not, I can order you factory bulbs in any color
sales@spencershids.com is offline   Reply With Quote
Old 08-28-2009, 05:08 PM   #6
alexice1421
ooo ok its not the color im really worried bout its the actual brightness, i like having bright HID's cuz of the illuminating ability
Old 12-04-2009, 11:51 AM   #7
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
the vettes use D1S bulbs.
it wouldnt be too farfetched if maros used that bulb as well
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 12-04-2009, 02:02 PM   #8
Hyp
I've been lost...
Hyp's Avatar
Drives: 2010 SW 2SS/RS W/IOM LSA Swap
i thought 12000k will suck in visibility compared to the stock ones. the higher the number = the lesser the lumens? something along these lines 8000k is more blue. 6000k is a bit less blue but brighter. 4300k is brigtest with little blue
found this: http://www.mcculloch-hid.com/ebay/Color%20chart.jpg
anyone know what temperature our stock HIDs burn at? 5k?
Hyp is offline   Reply With Quote
Old 12-04-2009, 04:57 PM   #9
sixty9fordkiller
either 4300K or 5000K. no more, no less.
Im gonna change to 6500K (White with very slight hue or purple) as soon as its confirmed whether its D1S or D2S bubls that the car takes
Bone Stock
Old 12-04-2009, 07:09 PM   #10
Sherwood SS
Sherwood SS's Avatar
Drives: Black SS/RS
12000k is way to high. I would say no more than 6000k (white w/ a blue tint).
Sherwood SS is offline   Reply With Quote
Old 06-22-2010, 09:04 AM   #11
phenixdragon
Drives: 2010 Camaro SS
Old post but I disagree. I always run 12000K. They are brighter then the stock HIDs in car but not as bright as some lower temperature. And I thin it looks the best and lights up white like a black light is hitting it.
phenixdragon is offline   Reply With Quote
Old 06-22-2010, 09:49 AM   #12
BFxenon.com
Drives: Camaro
D1S is the replacement bulb
http://www.bfxenon.com/BFXenon_com_D..._p/hid-d1s.htm
BFxenon.com is offline   Reply With Quote
Old 06-22-2010, 09:51 AM   #13
BFxenon.com
Drives: Camaro
i agree... well, different manufacturers have different color ranges in their output level. Our 6000K is pure white while others 6000K will have some blue.
our 12000K is purple.... which is what I don't recommend.
Old 06-23-2010, 07:11 AM   #14
ADIO SS
ADIO SS's Avatar
Drives: 2010 White SS/RS L99
Yes, they are D1S. I replaced the factory blub (Osram's) - my estimate they were about 4300k range with Osram's 6000k with very little difference. Stepped up to 8000k, now we are talking. White light with hint of blue.
Easy mod, essentially the blub has a self contained ballast and is held in place with a twist ring on the inside.
I was told, and it appears to be true, that you can't compare the k rating from those HID kits that replace the factory blub in 'non HID housings' with ones like we are discussing here (D1S).
I thought the 6000k would do it, but the 8000k was the look I wanted. Hope this helps.
BTW, AAC lighting was very good about the exchange, no issues from the 6000k to 8000k. Even though they call it Oracle lighting, it was the same manufacture blub as the stock blub, and they claim a warranty for life. The pair set me back $225.
ADIO SS is offline   Reply With Quote
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Cosmetics and Lighting Modification Discussions 36 04-02-2020 05:32 PM
Winner, winner - Jalopnik compares the Big 3 Number 3 5th Gen Camaro SS LS LT General Discussions 31 04-17-2011 03:24 PM
An interesting Camaro (and GM) story! I just bought my 2010 Camaro! Camarodriver Camaro Price | Ordering | Tracking | Dealers Discussions 12 11-28-2010 03:52 PM
10 Camaros that should be built SSOOCH 5th Gen Camaro SS LS LT General Discussions 47 11-03-2009 05:46 PM
Camaro Chat 9:30-10:00 jdpickering 5th Gen Camaro SS LS LT General Discussions 25 07-22-2008 02:11 PM
