Old 12-14-2014, 08:11 PM   #1
Ryan87mets
Ryan87mets's Avatar
Drives: 2018 1SS 1LE M6
2013 v6 with only 15k miles and my breaks squeak....
so this is kinda embarrassing having a new car and my breaks already squeak. i notice alot when i first start driving in the car in the morning. does something need to be replaced already? let me know what u guys think thanks!
Ryan87mets is offline   Reply With Quote
Old 12-14-2014, 10:26 PM   #2
inferno2ls
Drives: 2013 camaro 2ls
Yeah same I'd love to know the answer to this
Injen col air intake, vmax ptb, solo high flow cats, bbk aluminized xpipe, mrtv2, Rx catch can, BMR strut tower brace.
inferno2ls is offline   Reply With Quote
Old 12-14-2014, 10:31 PM   #3
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
How hard have you driven the car?
Be honest....
You may need to have to rotors re-surfaced.
How much pad life if left? Have you looked at the ware indicators?
Mods:
Old 12-15-2014, 02:39 PM   #4
Ryan87mets
Ryan87mets's Avatar
Be honest....
so I guess I drive it a little hard but I will only accelerate fast when no one is in front of me. I don't slam on the brakes at all, and honestly I barely even use the brakes I use the trans to slow the car down most of the time, and no I have not check pad life/ware indicators, just started happening last week and I noticed it just about everyday since
Old 12-15-2014, 03:13 PM   #5
jimbow
Drives: 2012 2LS Camaro - RIP 10/3/2021
Pull a wheel or two and see if you have excessive pad transfer buildup on the rotors. check your pad thickness (inside and outside).
Your "hardly use the brakes, just use the trans to slow down" can be contributing to your issue.
You could try bedding in your pads and see if that helps.
You'll need a long straight where you can get up to a decent speed and almost stop to do it. Stay legal! I have an old parking lot I use if I'm not at the track.
jimbow is offline   Reply With Quote
Old 12-15-2014, 03:18 PM   #6
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
It could be the rotors but it's most likely your rear brakes and more then likely the stock brake pads i had this issue and when i pulled the wheels off and checked the brake pads the semi-metallic brakes were more like 75% metallic when i switched them out zero brake noise i've since gone to ceramic but if it is this that amount of metal content will ruin your rotors over time.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile
Evil-Bee-NH is offline   Reply With Quote
Old 12-15-2014, 03:43 PM   #7
Roaddog
Roaddog's Avatar
Drives: 2014 LS V6 bright yellow
new brakes need to be broke in by doing some high speed braking as listed two posts up if not done you will have short brake life and all sorts of noises vibrations etc being a baby with new brakes is a no no drive like a mad man for a week or so then your brakes will work properly
Roaddog is offline   Reply With Quote
Old 12-16-2014, 02:55 PM   #8
Ryan87mets
Ryan87mets's Avatar
thanks for all the replies, I never did break them in when I got the car last year so I take it would be to late now to do that? and also when I get a chance ill check out the pad life. also could it be something to do with it being winter out and maybe the salt is getting to them?
Old 12-20-2014, 11:20 PM   #9
Blueraycamaro
Drives: 2013 2LT RS camaro
I have also a 2013 2lt RS package with 24090 miles and my breaks are squeaking bad when the rotors are cold, after warming up the brakes the squeak is not noticeable. I do drive the car. But is their a brembo package for the 2lt package?
Blueraycamaro is offline   Reply With Quote
Old 12-21-2014, 09:36 AM   #10
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
The SS Brembo's off a V8 car work great on the V6.
Trust me I know.
Mods:
Old 12-21-2014, 10:00 PM   #11
Blueraycamaro
Trust me I know.
Does any modification have to be done. Is it just rotors and pads or calipers need to be change too?
Old 12-23-2014, 03:24 PM   #12
jimbow
If you do all 4 corners v6 -> brembo you need to trim the rear dust shields to fit the rotors. Use the brembo pads the v6 pads will NOT fit.
Find someone selling their SS take offs (calipers, rotors and pads).
