Old 12-15-2014, 01:47 AM   #1
CAP'N B
Cajun Mariner
CAP'N B's Avatar
Drives: 10 Camaro SS/RS 15 Camaro Z/82 AGM
Oil leak on 2010
I have oil seeping out of my pan on my 2010, is this a regular occurrence? I do road course the car and have been given the meatball flag for it smoking excessively. I didn't know it was leaking at the time, but I believe that it is from this leak. I read somewhere that it could be that 8 qts of oil is too much. Please someone point me in the right direction
'10 Camaro 2SS/RS Red Jewel VVTLS3/A6
'15Camaro Z/28 Ashen Gray
CAP'N B is offline   Reply With Quote
Old 12-15-2014, 05:52 AM   #2
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
This is a known issue on the V8 cars. They will have to drop your sub frame in order to get to the pan for the repair. Since it appears you're out of warranty, your wallet will be a few pounds lighter after the fact.
There are many threads on this problem if you search the forum.
http://www.camaro5.com/forums/showthread.php?t=218606
Here is just one.
TheHorse13 is offline   Reply With Quote
Old 12-16-2014, 06:57 PM   #3
myold88
myold88's Avatar
My early '10 SS pan started leaking this past Summer. I had it repaired under warranty just
before my 5 year warranty was up. I heard it's a $2,000.00+ repair job if out of pocket.
Old 12-16-2014, 07:22 PM   #4
FASTDIESEL
FASTDIESEL's Avatar
Drives: 2010 2SS/RS L99 SLP Cosmetics
+3 Oil pan/t-joints.
13.244 @ 104.91 100% stock (#17).
Now - Mike Norris catch can. 245/50/19 Firestone Wingfoot A/S on LT2 black powder coated rims (square). 1 7/8" Speed-Engineering LTH, off road pipes, tune.
Now 12.93 @ 109.13.
FASTDIESEL is offline   Reply With Quote
Old 12-17-2014, 04:58 PM   #5
JT Camaro
JT Camaro's Avatar
Drives: 2018 ZLE
ive got the same problem here and out of warranty. Its not leaking much, so here is to driving it till its worse
JT Camaro is offline   Reply With Quote
Old 12-19-2014, 09:48 PM   #6
CAP'N B
Cajun Mariner
CAP'N B's Avatar
It's been brought to the dealership 2 times already, July 2013 and a week ago for the same problem, under warranty, the car won't be 5 years old yet until February 2010 and it doesn't have 50,000 miles on it yet so it should be covered under the power train warranty, so far the dealer doesn't want to fix it, and says it's not guaranteed changing the gasket would fix it anyway
Old 12-20-2014, 12:06 AM   #7
forklord
forklord's Avatar
Drives: 2010 2SS
could be the oil cooler gasket as well. there was a service bulletin on it. very slow leak. its near the pan so hard to tell for sure unless you get it on a lift
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 12-20-2014, 12:59 AM   #8
FASTDIESEL
FASTDIESEL's Avatar
Obvious your dealer is not too familiar with your car (or worse, just doesn't give a hoot!). I wouldn't let them work on it with an attitude like that. They may do more harm than good. Take it to another dealer.
My "little" dealer in a small town, jumped right on mine. Didn't buy the car from them (bought used), and it was less than a thousand miles from being out of powertrain warranty! Great service! You shouldn't have to beg the dealer to do their job.
Now 12.93 @ 109.13.
Old 12-20-2014, 07:01 AM   #9
TheHorse13
TheHorse13's Avatar
Find a new dealer immediately.
The proper way to determine where the leak is coming from is to drop dye into the crankcase. If it is the pan, a gasket change, along with an actual pan change will certainly stop the leak.
Old 12-20-2014, 09:04 AM   #10
myold88
myold88's Avatar
This- I bet that dealer doesn't have anyone qualified to do the repairs.
Old 12-20-2014, 10:44 AM   #11
ELIC1
Drives: black and silver
i know oil leaks dont Discriminate on any year car but is this a 2010 camaro issue. seems like all i see is people with the 2010 not the 2011
ELIC1 is offline   Reply With Quote
Old 12-20-2014, 06:35 PM   #12
TheHorse13
TheHorse13's Avatar
Mine is a 2011 and I had the dreaded big 3 oil leak issues.
Old 12-20-2014, 06:46 PM   #13
ELIC1
how many miles on it before you new you had it
Old 12-21-2014, 08:50 AM   #14
TheHorse13
TheHorse13's Avatar
The first leak was the oil cooler itself which happened at about 5k miles. From there, the oil cooler gaskets went south, which happened at 6k. After that, the oil pan gasket started leaking at around 9k. The solution per the TSB was to replace the oil pan itself and the gasket. Apparently early oil pans had some sort of problem according to the service manager. They had to drop the entire front rack to make this repair.
The only thing that I was spared on was the rear main seal leak due to porous casting flaws in the block. Early cars have this problem but maybe mine was made late enough to avoid that mess. Maybe it will start later. Who knows.
I had a ton of other issues, all before 24k miles. Things like the radiator exploding, power steering knuckle leaking, brake reservoir and cap leaking...on and on.
I never thought that I would own a car of worse quality than my (bought brand new) 1988 IROC but 26 years later, the new title of worst piece of junk I have ever owned goes to the Gen5 Camaro.
