Old 12-19-2014, 10:12 PM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
Cam Motion cams
I have a whiny Comp Cam that doesnt produce the power it should with my mods 447hp/406ftlbs from a Night Fury with my mods is way to low. Im thinking of getting a different cam and was woundering what I could expect from a Cam Motion stage 3 http://store.cammotion.com/catalog/p...da57449a024668. Im going to ask Mike at New Era if he will do one of his cams done at Cam Motion. Im not going to look for hp I want low end torque. Its a street car. I might take it to Watkins Glen but i want it to be best on the street.
JCunningham is offline   Reply With Quote
Old 12-20-2014, 07:48 AM   #2
1sick_eg
Drives: 14 Camaro 1LE,328i, and some Hondas
With that duration and LSA, you will have good streetability and power. What are your specs on your current cam?
I'm currently running a titan vi cam motion cam 232/238 .621/.603 113LSA if I remember the numbers off the top of my head correctly. Pretty good streetability. Some vacuum loss. Made 484/444 on a load bearing dyno. 400wtq at 2000 rpms.
14' Camaro 1LE - Now self-tuned
FRH ported heads, Cam Motion LL solid roller, Jesel rockers, Morel lifters, Kooks headers, Corsa exhaust, ADM intake, Stock compression/bore/stroke
551whp 504wtq
1sick_eg is offline   Reply With Quote
Old 12-20-2014, 08:10 AM   #3
1sick_eg
Nevermind. I see you're running a nightfury cam. I'd say there is another issue as far as power is concerned. As far as the noise goes, pull that thing asap to inspect it. I'd hate to see your bearings trashed from it.
551whp 504wtq
Old 12-22-2014, 01:14 AM   #4
Camaro Dude
Camaro Dude's Avatar
Drives: ‘13 1LE
Those are nice numbers, liking the torque too!
I'm calling Kip tomorrow to inquire about the low lash solid roller option, and cam spec selection for my application.
Camaro Dude is offline   Reply With Quote
Old 12-22-2014, 01:42 AM   #5
Jewbeanie
Jewbeanie's Avatar
Drives: 2010 White Camaro 2SS/RS
Yeah I just bought a Nightfury Cam and its made by Cam Motion. My confusion is that yours was made by Comp Cams??
Jewbeanie is offline   Reply With Quote
Old 12-22-2014, 02:32 AM   #6
MightymouseSS
Drives: 2011 LS3
Lethal switched to cam motion grinds. Before they were ground by comp cams.
Stainless Works Headers
Vmax TB
SLP loudmouth 2
Nightfury Cam
Mike Norris CC
Tuned by Southwest Speed
MightymouseSS is offline   Reply With Quote
Old 12-22-2014, 07:50 AM   #7
1sick_eg
Thanks. Yeah, the car feel pretty good. I wish I had put more thought into my valvetrain. I went with quality parts, but wish I had just gone solid roller. A lot of people complain about lash adjustment, but I always enjoyed simple maintenance like that. It's easy. Not to mention Kip said with these low lash setups that after a few heat cycles, you shouldn't have to adjust it hardly ever. I could always hear when my valvetrain needed the smallest amount of adjustment. Let me know what you decide.
551whp 504wtq
Old 12-22-2014, 12:33 PM   #8
DieselMD @ Futral
DieselMD @ Futral's Avatar
Drives: G8
Let us know if we can help. All our cams are ground by Cam Motion.
DieselMD @ Futral is offline   Reply With Quote
Old 12-22-2014, 01:32 PM   #9
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
I would have a shop/tuner that knows what they are doing check your setup and see what your problems are first .Most cars respond very well to the Nightfury cams . .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 12-22-2014, 10:30 PM   #10
Camaro Dude
Drives: ‘13 1LE
Spoke to Kip today, I think my quest for a cam has finally ended. He spec'd me a cam, and an alternate one as well....I have some food for thought here, decisions decisions!
Regarding low lash rollers, it's almost a no-brainer, unless the budget doesn't allow it. Some parts will have to be replaced, and an extra G note or two may not be in the cards, when the pecking order of things is finally budgeted out.
The good news is, based on Kips post in that solid roller thread elsewhere, that taller valve covers are not needed, thanks to adjustable roller rockers he sourced .
Sadly I'll be sticking to hydraulic, but I'm getting excited about these two cams he spec'd me, just trying to think......
Old 12-23-2014, 12:37 AM   #11
Josh @ Spartan LSX
Josh @ Spartan LSX's Avatar
Drives: A wrench
A lot of companies are jumping ship with Comp and going over to Cam Motion. After 3-4 years of consecutive failures it was about time.
Once I left Comp I tried Bullet, Isky, Lunati, etc. Cam Motion always seemed to outperform the others and with much smoother (less abusive) lobes the valvetrain stability is where it should be resulting in a longer lasting valvetrain.
Josh @ Spartan LSX is offline   Reply With Quote
Old 12-23-2014, 07:47 AM   #12
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
I went cam motion, and couldn't be happier. Its nice knowing my valve train is safe, better sleep at night!
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 12-23-2014, 10:01 AM   #13
TXM62SS
TXM62SS's Avatar
Drives: 2012 2SS/RS LS3
x2
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA
Kooks 1-7/8" LTs w/ Cats
Roto-Fab, Bo White TB, Borla Touring Catback
3.91 1LE Gears, MGW
Tuned by Pat G
TXM62SS is offline   Reply With Quote
Old 12-23-2014, 10:50 AM   #14
JANNETTYRACING
JANNETTYRACING's Avatar
Very similar to my 470 cam which is available on CamMotion core.
Let me know If I can help.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
