12-22-2014, 09:16 PM | #1 |
Drives: 2022 2SS Vert (on order) Join Date: Dec 2013
Corsa or Headers?
Preparing for spring upgrades for my '13 ZL1 Vert and could use some guidance....
I am planning on doing the Lingenfelter 630HP (Stage 1) package but also was considering an exhaust upgrade. I'm trying to decide between the Corsa exhaust (recommended by LPE) or headers/hi-flo cats. The goal primarily being a more aggressive exhaust (not obnoxious) and no drone (my wife still wants to take trips in the car ). FYI, I do have the MTW controller with the stock exhaust and it still seems a bit too tame. Appreciate any suggestions, pros/cons... |
12-24-2014, 03:28 AM | #2 |
#00193
Drives: 14 ZL1 - 12 CT Join Date: Oct 2014
I'd go with headers first. With headers you would get the most HP gain out of the exhaust system, plus the exhaust note you're looking for .
12-24-2014, 04:53 AM | #3 |
Drives: 2013 Camaro ZL1 Join Date: Jun 2010
I just did stainless works long tubes with their chambered exhaust and I love it.
2013 Camaro ZL1 Black M6
Roto-Fab Intake, Apex Catch Can, Stainless Works 2" long tube headers with cat delete, Stainless Works 3" retro chambered catback, ATI Super Damper with 10% overdrive lower pulley, tuned by JRE. Sitting on Black MRR 228's wrapped in MT's. |
12-24-2014, 05:41 AM | #4 |
what numbers did Ted give you after you loaded the tune. rwhp/rwtq tks jim
JRE 135 RWHP & 93 tune, SCT-4, ATI Superdamper, CAI, Elite2 CC , ID850 injectors, NGK TR7IX
NAPA Green Belt Lingenfelter 9.55” L220290709 (23%) pulley Lingenfelter LPE idler relocation bracket DynaTech SupperMaxx LT headers/Supercats BMR 1" lowering springs BMR toe rods, BMR trailing arms, Z/28 wicker bill extension. HAWK HPS, MRR228's, M/T ET SS's P305/35-20 |
12-24-2014, 06:30 AM | #5 | |
Drives: 2013 HWSE Indy Festival #26 Join Date: Mar 2011
So now, I have moved to Jannetty 75RWHP. And Pfdat headers. Cannot wait to get it installed over the winter. Do your research.
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan |
12-24-2014, 10:16 AM | #6 | |
Drives: 2013 ZL1 A6 #7860 Join Date: Apr 2014
They said they will not tune for long tube headers? WTF? |
12-24-2014, 10:29 AM | #7 |
Let's go Rangers!
Start with headers and work back. Headers give you sound and power, an exhaust just sound which after headers you may not even need or want.
12-24-2014, 10:30 AM | #8 | |
Let's go Rangers!
12-24-2014, 01:07 PM | #9 |
Ragtop Rocket!!!
Drives: Black on Black Convertible Join Date: Mar 2013
Headers ditch the Cats and use the exhaust controller. You'll be surprised how quiet it is and how loud it can be. We do road trips with them closed for the wife I run with them open as a noob repellent!
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package. 744rwhp 727rwtq |
12-24-2014, 04:14 PM | #10 |
Going for Plaid
Drives: 2011 C6 Join Date: Jan 2010
I have headers with no cats and the stock exhaust. It's crazy loud with the flaps open. Sounds great flaps closed too. No drone at all going down the road.
2014 ZL1, manual trans, carbon hood insert, Rotofab, Pacesetter 1 7/8" headers, 1" drop BMR springs, stock pulleys, 91 octane tune, 545rwhp & 515rwtq
Serviced and modded by Cordes Performance. 2011 C6, 750rwhp, forged LS3, ported LSA heads, Vortech Ti-trim, 227/243 115+4 Lunati cam, ported LS3 intake, Alky Control methanol, Pfadt sways/shocks/trans mounts, Pfadt tri-y headers(Sold 6/28/14) |
12-26-2014, 11:33 PM | #11 |
Thanks for all the input... sounds like headers are the best way to start
12-28-2014, 07:14 PM | #12 | |
Drives: 2013 ZL1 Join Date: Oct 2014
Same here. Only flaps always open. Prius repellent.
12-28-2014, 08:33 PM | #13 | |
Drives: '21 ZLE A10 Join Date: May 2012
12-29-2014, 01:56 AM | #14 |
Drives: 2015 Camaro ZL1 Summit White Join Date: Aug 2014
