Old 01-09-2015, 05:59 PM   #1
silkrckt
silkrckt's Avatar
Drives: 2017 Garnet Red 1LE
wideband and tuning
Is one required for tuning? I see companies offering mail order tunes and the customer just logs the car. Does this logging require a wideband? I ask because when I tuned my last car I didn't have to buy one. I believe the car had one from the factory. It was a turbo car. I want to tune my camaro but don't know if the wideband is required 100% to get a decent tune.
Thanks for the help
New Camaro --- 2017 SS 1LE Garnet Red -stock
Last Camaro --- 2014 2SS || 6 speed || NPP || Kooks 1 7/8 LT +Cats || Apex Catch Can || BW PTB || CAI induction || 12.99 @ 111 stock tires, 2.1 60'
Old Camaro --- 94 Z28 Vert-- Miss it.
silkrckt is offline   Reply With Quote
Old 01-09-2015, 06:47 PM   #2
jonathanmoguel
MM.CC
jonathanmoguel's Avatar
Drives: 2010 Camaro 2SS LS3
a wideband helps to dial in the fuel trims more percise than using the infomation off the handheld or tuning software.
2010 camaro ss: Volant cold air intake, BBK Shorty Headers, JBA offroad midpipes, Diablosport tuned (custom tune), SLP II loudmouth axleback, ZL1 Short shifter, nitrous outlet wet "100 shot"
jonathanmoguel is offline   Reply With Quote
Old 01-09-2015, 11:22 PM   #3
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Drives: Black & Yellow 2SS/RS LPE LS7 427
You will need a AFR wideband gauge with a 0-5v analog output to log AFR. Your remote tuner will need that PID to tune for you. If your Runing FI you will also want the gauge to monitor AFR when under boost.
Bryan
My Build Journal
Built, Tuned and Maintained By........
LS7 427 is offline   Reply With Quote
Old 01-10-2015, 10:46 AM   #4
silkrckt
silkrckt's Avatar
Bryan
Thanks. Makes sense. I just haven't read that anyone purchased one for remote tuning. So, I have to purchase the wideband and pay for the tune and buy the HP tuners software? Think I'll just tune myself if I have to purchase everything required to do so.
Old 01-13-2015, 10:14 AM   #5
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
You don't have to have a wideband for remote tuning, but it's never a bad idea to have one. If you don't have a wideband, they will use fuel trims from the narrowband sensors to correct fueling.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 01-13-2015, 01:54 PM   #6
JANNETTYRACING
JANNETTYRACING's Avatar
Thanks for the help
I typically don't require them for simple bolt ons like you have.
I have near perfect calibrations for all the major brand parts and combination having done over 2500 Gen5 Camaros.
When you get in to cams, Forced induction, or off brand parts I will require a Wide band O2 gauge to be logged using the SCT handheld also used for custom remote tuning.
The SCT X4 can log up to 4 analog inputs, reads and clears codes, stores your factory tune file, can store up to 10 custom tunes, and is a very powerful datalogger.
Feel free to Call, Email PM me for more info.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 01-13-2015, 02:54 PM   #7
silkrckt
silkrckt's Avatar
What is the range of the narrow band sensors vs the wideband?
Old 01-13-2015, 04:41 PM   #8
JANNETTYRACING
Narrow bands are only accurate at Stoich 14.7:1 above and below who knows.
Wide bands are accurate from 8.0:1 to 20.0:1.
Old 01-15-2015, 04:03 AM   #9
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Thanks for the help
I know this is a few days old, and as stated you don't "need" to have a wideband to tune basic bolt-ons. If you want to tune your car, and learn how to do it at the same time, then I would recommend you do just that. Get a innovate, or AEM Wideband gauge, plug it into the extra O2 bung that some headers have (some not all.....you can always use the factory rear O2 sensor location) and purchase HPTtuners (get pro not standard) and have at it!
Thats a great way to learn. If you get to a point where you cant go any further and are scratching your head, then bring in one of the well known and respected tuners here on C5 or wherever you chose to get them from, and have them "remote" tune your car for you, most of them should welcome the addition.
After your done having, either you or someone else, tune your car, you can sel the wideband here on C5 forums for a great price and recoup some of your money back.
Hey that's what I did.....I learned a TON of things and got a killer tune in return!
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 01-19-2015, 09:59 PM   #10
silkrckt
silkrckt's Avatar
Thanks all for the feedback.
Killer thanks again. I never thought about picking up and selling the wideband.
