Old 01-19-2015, 04:06 PM   #1
david6509
Drives: 2010 Camaro 2SS
Send a message via MSN to david6509
Lingenfelter 10inch crank pulley?
Hello just wondering if anyone is runnin the 10inch crank pulley or 28% overdrive on a stock zl1? I am interested to see what boost figures you are getting out of it? Is it to much pressure for a stock zl1? Any advise would be much appreciated.
david6509 is offline   Reply With Quote
Old 01-19-2015, 06:22 PM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
works fine and I have used a 10" lower pulley with stock upper supercharger pulley for over 2 years. Boost is 15ish. This lower pulley is not recommended for extended use like road course duty as it will make the car overheat and IAT2s will skyrocket. For a cruiser and drag race machine, it will be perfect.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 01-19-2015, 06:51 PM   #3
ZL1Kid_AL
ZL1Kid_AL's Avatar
Drives: 2014 ZL1- Summit White M6
15lbs^^^^??? Wow. I'm at 12lbs with 10inch lower, stock upper.. Might be losing a pound from my 2" headers but wow 15lbs is crazy
All in the tune or? Haha
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
ZL1Kid_AL is offline   Reply With Quote
Old 01-19-2015, 09:16 PM   #4
Stephen12ZL1
Drives: '21 ZLE A10
Most likely due to your elevation...I am 130ft above and you are a mile high which surely effects your boost.
Old 01-19-2015, 09:58 PM   #5
david6509
Hey stephen i just looked at your signature, did you run a 10.52@131.6 with the standard cam?
Old 01-20-2015, 06:55 AM   #6
Stephen12ZL1
Drives: '21 ZLE A10
Stock cam, stock heads, no ported anything, with 100 octane. Supercharger never removed from car and valve covers never removed.
Old 01-20-2015, 08:12 AM   #7
david6509
That's really impressive. I am doing something similar, would be great if I could get 130mph, it's going in on Friday for install and tune so I will post results when I get them. What sort of power do you think it will make with the below mods? It's a automatic aswell.
I just ordered the 160degree thermostat today.
Ceramic coated inch and 7/8 Extractors with no cats and PWR heat exchanger
Ported LSA throttle body painted black
Lingfelter 10inch crank pulley kit and idler relocation
KPM1000cc injectors
Over the radiator air intake
Elite engineering catch can with some black fittings and braid
Old 01-20-2015, 08:43 AM   #8
david6509
Thinking I might have to do a meth system as I do a little bit of road course maybe once every two months.
Old 01-20-2015, 09:01 AM   #9
Stephen12ZL1
Drives: '21 ZLE A10
Nice...you will be close to 600rwhp on 93 octane depending upon which dyno is used and correction factors etc. Make sure they double check the fuel pressure as some cars really start dropping when pushing larger injectors at higher hp levels. A boost-a-pump may be necessary. Somehow mine is still o.k. with no fuel pressure drop at all.
Old 01-20-2015, 09:06 AM   #10
Stephen12ZL1
Drives: '21 ZLE A10
Oh, don't run that 10" lower at the road course...you will be sorry because of all of the heat generated even with the cooling upgrades. Even a 9.55" lower is too much because of the amount of time the car is "boosting". The meth may "band aid" you well enough to get by, but I wouldn't rely on that because the tank may run dry. I run an 8.66" lower(10%) at the road course and that is consistent and safe. I tried the 9.55" lower once and it proved to be too much and the car went into reduced power mode because of excessive heat even at 65 degree ambient. The larger lower pullies only help hp for the first lap then the ECM dials back timing and really doesn't produce much more hp.
Old 01-20-2015, 11:52 AM   #11
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
See this is great stuff to know right here.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 01-20-2015, 04:35 PM   #12
david6509
This is the type of racing I do. I only really give her some on the two main straights and cool down through the rest. It's pretty much just lining up people next to you and racing on the main straights. Do you think the 28% OD will be fine for it? Have a look at the YouTube link below to see.
http://youtu.be/dFHZ-4bMzGw
Old 01-20-2015, 08:46 PM   #13
Ledbetterjw
Ledbetterjw's Avatar
Drives: 2011 Chevrolet Camaro SS
What lower would be recommended for up to 2 hour spirited driving back country roads and twisties?
Ledbetterjw is offline   Reply With Quote
Old 01-20-2015, 08:51 PM   #14
Stephen12ZL1
Drives: '21 ZLE A10
VIR full is the only track I have run with the ZL1 and it is a similar configuration. 3.27 miles and 25 min sessions are brutal. 5 min everything is fine, but after that the water and oil temps start to creep up and the shorter sections aren't enough for a cool down. Autocross would be fine as those laps are not long and anything would work well. Full throttle on long straights produces a ton of heat even with the airflow and cooling upgrades. I have many laps logged and keeping the boost low is the only way to control excessive heat in the ZL1. My boost with the 10% overdrive lower (8.66") is 11ish psi vs the stock 8.6 psi and that is perfect for me. My hp is much lower 508/540 rwhp with a conservative road course tune, but it works well. Amazingly, it still runs 11.30@121 with the lower hp tune at the strip on a so so DA air day (+1500ft). Getting the brakes right with high temp fluid and watching pad wear is more important that hp. The stock pads are very good but Hawk DTC or Porterfield (ask Jess) are better after the stockers wear out.
