Old 01-29-2015, 01:54 PM   #1
2SS2010
Drives: 2010 2 SS
3.91 install Anyone do it themselves
Shed any light on the matter, I've done plenty of 8.8 mustang gear installs any difference doing it in a Camaro diff?
2SS2010 is offline   Reply With Quote
Old 01-29-2015, 01:58 PM   #2
beasstmode
Drives: 2011 camaro ss
There's a few threads on people doing it themselves and discussions over it on here man, it's cake if you know what your doing
beasstmode is offline   Reply With Quote
Old 01-29-2015, 02:26 PM   #3
2SS2010
Drives: 2010 2 SS
My concern was specialty tools other than a dial indicator. every mustang I have done reused the same pinion shim slap it in check backlash and pattern throw cover on and never hear a peep out of them again.
Old 01-29-2015, 05:21 PM   #4
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I'm writing up an article on my install and if you have done gears before you can do these.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 01-31-2015, 04:20 PM   #5
2SS2010
Drives: 2010 2 SS
Thanks john do you have the specs?
Old 01-31-2015, 04:40 PM   #6
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
The only other tool I've heard of people needing is a differential spreader. Most people that I've heard doing it themselves said they was able to reuse the factory shims as well.
Old 02-01-2015, 12:15 AM   #7
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
You can get around the spreder by putting a shop rag between the pinion and ring gear and turning the yoke.
For some reason I am the only guy who ran into a problem getting the yoke to seat on the new pinion and had to take it to a guy who builds them all the time.
Old 07-03-2015, 07:10 PM   #8
Superfly1
Superfly1's Avatar
Drives: 2010 Camaro 2LT #2197
You aren't the only guy. I am having this same issue in trying to reassemble mine. Seems I can get it to a point, then no more. I am using the heavy duty Craftsman impact (says 780 ft lb, but who knows) on it. Anyone have a better way other than handing it off to a shop?
CAI intake | OBX LT Headers | Flowmaster AT Exhaust | Trifecta Tune | SS Rear Diff, Axles & Driveshaft
Zex 100 Shot Nitrous | Konig Airstrike Wheels | Custom Engine Cover, Fuse Box & Underhood Bowtie
Eibach Springs & SS Sway Bars
| BMR Strut Brace | Drake Shifter | Vitesse Paddles | 13.26 @ 105.88 mph
Superfly1 is offline   Reply With Quote
