View Poll Results: Which one would you prefer as of right now knowing the downfall fall of each system?
Scosche 43 62.32%
Metra 26 37.68%
Voters: 69. You may not vote on this poll
Old 01-31-2015, 10:59 PM   #1
jesse454545
Drives: 2011 CAMARO 2SS/RS
scosche or Metra ??
As of right now most of you have had time to get the pros and cons of both systems. I am looking to upgrade and would like to know which one is better and what would be the downfall of the other? Please vote on the toll, thanks
jesse454545 is offline   Reply With Quote
Old 02-01-2015, 01:26 AM   #2
GetSmart
GetSmart's Avatar
Drives: 2013 Black SS
Read too many problems with Scosche, so I got a Metra. No problems so far, I've had it for over a year.
Rotofab CAI, VMAX PTB, Borla S axle-back, Dynatech SuperMaxx 1 7/8" headers/HF cats, No weeds exhaust diverters, Apex air scoop & catch can, Rohana wheels, MPD1 Z-Force Hood, BTR Stage 3 cam, Vitesse Throttle Controller, etc...
GetSmart is offline   Reply With Quote
Old 02-01-2015, 01:21 PM   #3
darkrider01
Aural Assault Vehicle
darkrider01's Avatar
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali
I chose (and voted) the Scosche because I felt like the Metra just looked too cheap and that a modern muscle car should have modern touch-screen controls. That said - my Scosche kit has the remote range and TPMS interference issues, but they don't equal enough aggravation to forego the simplicity and ascetics that the Scosche brings to the table.
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Exterior Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber * OEM body kit Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Mosconi 6to8v8 w/ RCD * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692
darkrider01 is offline   Reply With Quote
Old 02-01-2015, 02:07 PM   #4
mydreamcar
My Dream Car
mydreamcar's Avatar
Drives: 2011 SIM LS3 1SS
Have the scoshe kit, zero issues excepts for a range issue at times. that being said I would suggest a pro install. lots of people are very handy but from what I have read, some issues could have been avoided by a pro install.
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
mydreamcar is offline   Reply With Quote
Old 02-01-2015, 09:56 PM   #5
370zyzfr1
Drives: 2014 Camaro Zl1 Tripple Black!
I went metra. Researched way too many issues with scosche. I really like it and NO issues.
370zyzfr1 is offline   Reply With Quote
Old 02-04-2015, 01:30 AM   #6
jesse454545
I heard you loose some features with the car if you go with either kits. One I heard about is your back up sensors? Not sure if they where legit but it's something I was reading on this forum.
Old 02-04-2015, 02:21 AM   #7
ZLWonton
ZLWonton's Avatar
Drives: 2014 ZL1 BRM
Not legit. I have a metra kit... back up sensors work just fine
ZLWonton is offline   Reply With Quote
Old 02-04-2015, 01:11 PM   #8
Knockoutpie
Knockoutpie's Avatar
Drives: 2014 2SS RS Coupe
The only feature you will lose is music information going to heads up display. That's it, HUD will still work, just won't show music information.
Knockoutpie is offline   Reply With Quote
Old 02-04-2015, 01:38 PM   #9
opossum
opossum's Avatar
Drives: 2013
Hallo,
i have tested both, metra and scosche. The metra works fine, no problems, but if you want to change carspezific options you have to go via xia-lcd connected to metra. With scosche this options are available but my TPMS failed. I own a camaro 2013, european version. Any weeks ago has mike wrote, that he got a firmwareupdate for scosche unit, that will fix this bug. I will test it at my camaro, but at this time my camaro "sleeps" in my garage. At the first of march i can drive it , then i hope, the winter has gone and the sun will shining more times.
EDIT 2015/05/15: Now i have installed my scosche with new uac and now all works fine. No issues, my tpms works fine.
best regards
opossum
Chevrolet Camaro - V8 - MT - 2013 - European Version - Inferno Orange/ Inferno orange - ACC Sidemarker ghosted - Dash Kit PAC RPK5-GM4101 with DNX8170DABS - Amp KAC-8406 - Sub Pioneer TS-WX110A - Rear- and Front-Camera - ACC Mail Slot Scanner RGB - Pedders Sportsryder - painted parts in engine compartment - black powder coated original rims - H & R wheel plates 20mm front and rear axle - 1 LE steering wheel - MGW Short shifter replacement - aluminum door Pins - ACS T4 Splitter - us-mirrors - ZL1 side rockers - High Wing Spoiler
opossum is offline   Reply With Quote
Old 02-06-2015, 03:10 AM   #10
370zyzfr1
Second that!
Old 02-06-2015, 04:55 AM   #11
SeaCompiler
...not a marine biologist
SeaCompiler's Avatar
Drives: 2012 Camaro RY SS LS3
My metra kit works fine with 0 issues and I have had it over a year. I chose Metra because it does not extend down as far and hey... who doesn't like the mudflap girl easter egg they have in it by holding down the snowflake for several seconds.
Forged 416 stroker Turbocharged with Huron Speed with Cam Motion custom grind,Tuned by Vengeance, 8psi, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock,, MSD 2-Step, ZL1 Rear End, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, 3 inch exhaust, blackouts, Lowered, Custom badges, Hines vents,RPI fender vents, Technostalgia Tail Lights, Metra Kit, Pioneer stereo, Morimoto RGB Halos,
"The Great Awakening" on gab.com
SeaCompiler is offline   Reply With Quote
Old 02-12-2015, 01:31 PM   #12
baranowski
baranowski's Avatar
Drives: 1968 Bronco,2001 Fatboy,2010 SS
I have the metra... no issues what so ever.
baranowski is offline   Reply With Quote
Old 02-12-2015, 05:53 PM   #13
OHIOSS
Russ
Drives: Yukon Denali, Charger, CamaroSS
Send a message via AIM to OHIOSS
I talked to a local car stereo company and they will NOT install Scosche any longer because of continual problems. They have been installing the Metra dash kit and have only had one that was a problem. I like the Scosche better but I think I'm going to go with the Metra kit in my 2010 SS.
OHIOSS is offline   Reply With Quote
Old 02-17-2015, 02:02 PM   #14
Yippee38
Yippee38's Avatar
Drives: '11 SGM 1LT/RS, '02 SOM Firehawk
I don't like the looks of either kit, but IMO the Metra looks less wrong. I can't be specific as to why I feel that way though. I went with Metra. I haven't installed yet.
Yippee38
Yippee38 is offline   Reply With Quote
metra, radio, scosche, stereo.
