Old 02-01-2015, 09:10 PM   #1
Bravo64
Drives: 2011 Chevy Camaro LS
Need some help, please.
I have a 2011 LS w/47,500m. Some things have been occurring since I installed a K&N cai system. First, I noticed the mpg declined a bit. I thought you were supposed to gain mpg. Secondly, I notice a lot of black soot accumulating on the inside of the chrome tail pipes. Also, the check engine light recently came on and according to autozone, it spit out code p0420. The check engine light has since disappeared. Question: is there a need to have it tuned after installing the cai? Any ideas? Looking for some assistance. Thank you
Bravo64 is offline   Reply With Quote
Old 02-01-2015, 09:14 PM   #2
PhelanZL1
PhelanZL1's Avatar
Drives: 2013 ZL1
to much oil on the filter, its getting on the mass airflow sensor, make the car run rich, and causes the cel to come on. Make sure there is not to much oli on the filter. Any car parts store sell mass air flow sensor cleaner, be careful the sensor is almost the size of a hair.
PhelanZL1 is offline   Reply With Quote
Old 02-01-2015, 09:23 PM   #3
MLAZ1990
Drives: 2012 black camaro 2LS
Interesting...going to keep this in mind next time I clean my intake!
MLAZ1990 is offline   Reply With Quote
Old 02-01-2015, 11:22 PM   #4
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
That MAF sensor shouldn't cause a P0420, which is a cat code for bank 1.
I would say can't cause it, but I'm hopeful you don't have to buy a catalytic converter so soon. Mostly just because I haven't taken mine off and I don't want to worry about them going bad at only 40,000
TommyTheCat is offline   Reply With Quote
Old 02-01-2015, 11:32 PM   #5
Homer2
Homer2's Avatar
Drives: 50th Anni.. coming home 11/01
I "thought" the K&N CAI required a tune?
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms.
Homer2 is offline   Reply With Quote
Old 02-01-2015, 11:36 PM   #6
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Kind of agree with what he ^^^ said. Don't think it's your MAF as it would cause Cels for both banks and it probably would throw codes for Too Rich fuel trims in addition to maybe the code you got.
camguynj is offline   Reply With Quote
Old 02-02-2015, 12:08 AM   #7
TommyTheCat
SHKE BKE
Drives: 2013 Camaro
Well it shouldn't set codes for those period, because the computer only uses the oxygen/air fuel ratio sensors to test the catalytic converters...
Old 02-02-2015, 08:34 AM   #8
Bravo64
Does the K&N require a tune after install?
Old 02-02-2015, 08:45 AM   #9
ChevyCamaroGirl
ChevyCamaroGirl's Avatar
Drives: 2010 CAMARO 2SS RS BLACK
No tune necessary.
ChevyCamaroGirl is offline   Reply With Quote
Old 02-02-2015, 09:40 AM   #10
camguynj
camguynj's Avatar
Front O2 is only used to set fuel trims (too much oil on intake filter results in less air, less air demands less fuel, too much less fuel demanded would trip a too rich fuel trim CEL). Rear O2 is used to test cat efficiency
Old 02-02-2015, 09:44 AM   #11
redhotcandy
redhotcandy's Avatar
Drives: 2012 2SS/RS
I had the almost the same thing happen when I had my V6 and installed a K&N cai. The CEL kept coming on, then off, then on but I cannot recall the code. Anyway, I called K&N and explained the situation, and they suggested I send it back to them and they recommended another model number. I did just that, and no more CEL's or any other issues whatsoever. I know somewhere in my postings I have the information on what model number I exchanged it for...hope this helps.
redhotcandy is offline   Reply With Quote
