Old 02-04-2015, 08:19 AM   #1
unstable vic
Drives: 2014 ZL1
Anyone using the O2 extenders with the mini cat converters in them?
Just wondering if they actually work. They are the extenders for the rear O2 sensors but they have the same material in them that our converters have. There like $50 each. My goal was to add headers and good high flow cats but not tune due to warranty issues. Car is brand new with 144 miles on it so I wanted to keep the warranty for a couple of years.
http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html
That's the link
unstable vic is offline   Reply With Quote
Old 02-04-2015, 03:14 PM   #2
14ZL1M6
14ZL1M6's Avatar
Drives: 2015 ZL1 Coupe A6 & 2002 ZO6
Who makes them? I've never heard of them. I'm interested in the input from people too. Great idea if they work!
14ZL1M6 is offline   Reply With Quote
Old 02-04-2015, 07:59 PM   #3
unstable vic
Drives: 2014 ZL1
That's the link
Old 02-04-2015, 08:33 PM   #4
14ZL1M6
14ZL1M6's Avatar
Thanks! It will be interesting to hear the feedback.
Old 02-04-2015, 08:46 PM   #5
14ZL1M6
14ZL1M6's Avatar
I also found this thread.....
http://www.camaro5.com/forums/showthread.php?t=277384
Old 02-04-2015, 09:09 PM   #6
Unreal
Drives: 2006 Z06
People have been doing that for years, they are not cats, just little defowlers that sometimes work to trick a car without cats.
Nick
Corvette Z06 -1200ish rwhp
Old 02-04-2015, 10:17 PM   #7
Nor Cal ZL1
Nor Cal ZL1's Avatar
Drives: 2013 ZL1 M6
Here is an image of the internals. Constructed from the same material as a Cat. Have not tested yet. Will update when I install the headers.
Nor Cal ZL1 is offline   Reply With Quote
Old 02-10-2015, 07:01 AM   #8
unstable vic
Drives: 2014 ZL1
They are mini cats if you were to look at the link you would see them. There not the $5 de fowler you buy at autozone.
Old 02-10-2015, 08:05 AM   #9
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Won't work. You will still get the P015B and P015D codes that relate to the front O2s. So changing the rear O2s for these won't help.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 02-10-2015, 12:54 PM   #10
unstable vic
Drives: 2014 ZL1
ok, I see. My misunderstanding. I thought it was ONLY the rear sensors that reported the cat event to the computer. I thought the front was for the actual air/fuel readings and had nothing to do with cat efficiancy
Old 02-10-2015, 01:20 PM   #11
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
if you are just worried about the CEL light going off, I'd go with a set of spark plug extenders from the parts store for $5.00.
try them first and see if it works. if not, then pony up for the $100.00 "cat extenders"
decent how-to thread
http://www.civicforums.com/forums/22...on-w-pics.html
I piss excellence
and fart awesomeness
Old 02-10-2015, 04:07 PM   #12
ZO6 Bryan
ZO6 Bryan's Avatar
You are right. The front O2s give the PCM the info it needs to adjust AFR. But there will still be a code related to response time of the front O2s with headers. Car will still run fine but codes will set unless adjusted in the tune.
Bryan 2018 ZL1 M6
Old 02-10-2015, 04:08 PM   #13
ZO6 Bryan
ZO6 Bryan's Avatar
Won't work.
Once again. This won't address the codes with the front O2s.
Bryan 2018 ZL1 M6
Old 02-11-2015, 07:30 AM   #14
CamaroSpike23
Truth Enforcer
Originally Posted by ZO6 Bryan View Post
Won't work.
I've done this on a number of cars on front sensors (some that only had 1 sensor period) and rear sensors and haven't had a problem.
I'm just saying that for the $5-10.00 investment, its worth trying before throwing down $100 JMO
I piss excellence
