![]() Drives: 2009 pontiac G8 gt Join Date: Feb 2015
Redline vs AMSOIL severe gear diff fluid
anyone have a preference or know which one is better. i heard the redline already has the additive in it
![]() Drives: 2013 Camaro RS 1LT, 6M Join Date: Jan 2013
I run Amsoil on all components that requires oil on both of my cars. IMHO it's the best oil out here, yes more expensive but worth it. I change my oil once a year and get in analyzed and after 18,000 miles the oil was still good and my numbers are great.
![]() Drives: 2021 Camaro 1SS 1LE Join Date: Aug 2014
Redline advertises that the additive is already in it. Others here have confirmed no problems with Redline when they didn't add extra additive.
I went with the Amsoil, which does need a little additive. I went that route just to "be sure." I didn't want to add the Redline only to have to double back with additive later. Both are fine. |
Drives: Nickey Super Camaro Join Date: Nov 2008
Both are excellent choices and both have additive, but in my experience you need to add additional additive to stock Camaro differentials.
Not true. I run Redline fluids and you need their friction modifier to add to the diff fluid.
#6 | |
I suspect both Redline and Amsoil have some additive. But, how much is necessary will differ with every trans. That's why I erred on the side of caution and just used the additive with Amsoil. From what I have been told, it is really hard to use too much additive (though possible). So, adding a couple ounces as a precaution should be fine. |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Flip a coin.
I used Lucas w/friction modifier in it...drained, filled and drove.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
#8 | |
#9 |
![]() Drives: 2013 2SS/RS M6 NPP Join Date: Dec 2012
I used AMSOIL and put in extra additive. 8k miles later and no issues. Hooks up nice and quiet around the turns.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 SS/RS M6 Commemorative Join Date: Apr 2014
I use Amsoil, has the additive in it already, but I added an additional ounce or two just to be sure.
#11 |
Destroyed by flooding
Drives: Wife's car Join Date: Mar 2014
On Redline's websight, they show that the have rear fluids with and without the additive.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Redline ,with the additive already in it . No need to add more.
OLD GUY FLYING FAST AND LOW
