Old 02-11-2015, 10:05 PM   #1
Jbaker901atu
Drives: 2011 Camaro LS
Exclamation Rod? Lifter? Exhaust?
Recently purchased a 2011 v6 camaro standard from a dealer. Has 45k miles. Noticed a very subtle but rapid low pitched knocking. Soundo like it's coming from the glove box area of passenger side and almost impossible to hear outside of the car, you really need to be in cabin. I don't hear it when I accelerate and It doesn't matter in the ac/heater is on or not. Did the old screwdriver to block trick and didn't hear any enhancement. Still owe 10k. On it so I'm freakin out a little. Still under powertrain warranty for a year. Thank you.
Jbaker901atu is offline   Reply With Quote
Old 02-11-2015, 10:06 PM   #2
Jbaker901atu
Also, it's on and off. Don't hear it all the time and can only hear it when it's quiet, like at night. Took it to local dealer, he said he doubts it's a lifter or rod. Thinks it is either exhaust or catalytic issue
Old 02-11-2015, 10:32 PM   #3
SmokinCarrot
SmokinCarrot's Avatar
Drives: 2010 SS/RS
Don't know but I'll "bump" the question. Good luck.
SmokinCarrot is offline   Reply With Quote
Old 02-11-2015, 11:04 PM   #4
Stealthpanda
Thread Ender
Stealthpanda's Avatar
Drives: 2010 Camaro 2SS/RS L99
There is a subtle, but noticeable, tick from the direct injection for 2010 and 2011 model LLTs. I think when the LFX came out they had found a "way" to reduce the ticking sound. Need a video to know if its a tick, knock, or squirrel living inside your valve cover.
Stealthpanda is offline   Reply With Quote
Old 02-11-2015, 11:15 PM   #5
Jbaker901atu
It's not the injector tick, that worried me at first.. it's so subtle not sure if my phone could pick it up.. more of a woodpecker sound.. much deeper than the injector tick
Old 02-11-2015, 11:16 PM   #6
Jbaker901atu
I noticed it more when my car is decelerating, but the speed of the knock doesn't seem to change
Old 02-11-2015, 11:18 PM   #7
omgitsmiketuck
omgitsmiketuck's Avatar
Drives: 2011 LS V6 (M) & 2019 LS I4 (AT)
my car has a ticking sound as well, but I've established its related to my AC. one of the bearings on one of my cabin fans is starting to go, and it ticks when at low speed. prolly not the same issue, but food for thought. seems like they used cheap fans in our AC.
omgitsmiketuck is offline   Reply With Quote
Old 02-11-2015, 11:21 PM   #8
Stealthpanda
Thread Ender
I do think the screwdriver trick would apply to something loose/moving under the valve cover. If this isn't engine related, it could be something with a pulley/belt/accessory related. The fans, as mentioned above.
Old 02-11-2015, 11:32 PM   #9
Jbaker901atu
Ok i appreciate the feedback... also, realistically, how likely is it for a ride with 45k on it to have a bad lifter/rod? This car showed no signs of abuse either. No pedal wear, no curb scrapes... nice tight clutch. Got it for a steal too. 16,500
Old 02-12-2015, 12:30 AM   #10
Jbaker901atu
Bump
Old 02-12-2015, 07:30 AM   #11
Gee
Silver Ice
Gee's Avatar
Drives: 2011 1LT Coupe SIM
Not trying to flame at all but, Video! How can we help you with a sound that we cannot hear? Thats like listening to a lady describing art via the radio then trying to draw it. Upload the video and Ill tell you within a few mins of you posting. GL man!
Gee is offline   Reply With Quote
Old 02-12-2015, 10:07 AM   #12
Jbaker901atu
Can you read or not.. I said my phone won't pick it up.
Old 02-12-2015, 10:13 AM   #13
Gee
Silver Ice
Gee's Avatar
Ok bro.... Good luck.
Old 02-12-2015, 10:42 AM   #14
MrChrisLS3
Drives: 2018 1SS M6
Typically, if it is specific rod the knock will sound heavy and solid and will match the rev's of the engine. If it is a lifter it will be similar but not as heavy and twice the speed of the rpm. The thing to note is that it will stand out noticeably over the rest of the engine noise. Sometimes a bad lifter will reveal itself at a little higher rpm than idle.
Also check or have check the PCV system, and possibly a top end clean. The issue with DI engines is carbon build up on the back of the valves as there is no fuel sprayed on them to keep them clean.
MrChrisLS3 is offline   Reply With Quote
6cylinder, camaro, knock, standard
