Old 02-14-2015, 06:51 PM   #1
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Z/28 oil/water temps in normal driving
My car runs so cool in normal driving that it almost seems wrong. I know how all of the nervous nellies in here talk about a "160 thermstat" will make the car blow up and is unsafe...blah blah. Obviously, GM has determined that the Z/28 needs a lower temp thermostat to run cool enough for a track dedicated vehicle. My car runs at 169-176 water temp and 170-176 oil temp when the ambient is in the mid 40s. My ZL1 with a 160 thermostat and a larger radiator runs at 176-180 water temp and always 210 oil. So, what is everyone else seeing for there typical cruising water/oil temps?
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 02-15-2015, 03:04 PM   #2
Stephen12ZL1
Drives: '21 ZLE A10
bump...anyone else have any temp readings from their DIC?
Old 02-15-2015, 05:42 PM   #3
macalot
macalot's Avatar
Drives: 1969 Z/28 + 2015 Z/28
Temps and weather have kept me from driving mine for a month or more now with no letup in the near future. I don't remember the numbers to be honest with you, sorry.
macalot is offline   Reply With Quote
Old 02-15-2015, 06:44 PM   #4
Zslash28
Jumanji
Zslash28's Avatar
Drives: '14 Z/28 - AGM - No A/C
This. Not for another month or more would I have good numbers.
Zslash28 is offline   Reply With Quote
Old 02-16-2015, 06:00 AM   #5
X25
X25's Avatar
Drives: '16 C7 Z51
If I remember correctly, LS7 reads oil temps from the bottom of the dry sump's oil container, which is a relatively colder place than the oil pan. So oil temp might read a bit lower, but coolant temp is puzzling. I wouldn't think GM can pass emissions with a low temp coolant thermostat? Had you driven long enough when you checked for temps?
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 02-16-2015, 07:01 AM   #6
Stephen12ZL1
Drives: '21 ZLE A10
at least 50 miles and it read 169°-176° the whole time.
Old 02-16-2015, 07:41 AM   #7
JD-ZL1
JD-ZL1's Avatar
Drives: 2013 ZL1 M6
Send a message via Yahoo to JD-ZL1
TEMPS
Hello Steve, Its your fault for the week of cold and now snow is on the way.. The minute you go buy a new toy to play with and see what happens.. Nice black Z/28.. Jim
JRE 135 RWHP & 93 tune, SCT-4, ATI Superdamper, CAI, Elite2 CC , ID850 injectors, NGK TR7IX
NAPA Green Belt
Lingenfelter 9.55” L220290709 (23%) pulley
Lingenfelter LPE idler relocation bracket
DynaTech SupperMaxx LT headers/Supercats
BMR 1" lowering springs
BMR toe rods, BMR trailing arms,
Z/28 wicker bill extension.
HAWK HPS, MRR228's, M/T ET SS's P305/35-20
JD-ZL1 is offline   Reply With Quote
Old 02-16-2015, 11:59 AM   #8
Stephen12ZL1
Drives: '21 ZLE A10
Thanks Jim
Old 03-02-2015, 10:40 PM   #9
Stephen12ZL1
Drives: '21 ZLE A10
Drove today with ambient in the low 50's and the cruising water temp stays at 172 and oil was 176 max. Anyone actually drive their Z/28? Did GM do something for the '15 model year because of high water/oil temps at the track? My ZL1s oil temp is minimum 210 and on track days it would hit 310.
Old 03-02-2015, 10:50 PM   #10
forklord
forklord's Avatar
Drives: 2010 2SS
Your zl1 is supercharged...temp gonna be higher.
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 03-02-2015, 11:28 PM   #11
X25
X25's Avatar
Drives: '16 C7 Z51
+1 and LS7 comes with dry sump. The engine oil temp is measured at the bottom of the dry sump tank, which also tends to be a cooler place than the actual sump of the engine.
Old 03-03-2015, 07:06 AM   #12
Stephen12ZL1
Drives: '21 ZLE A10
At cruise the supercharger is doing nothing...of course under load the supercharger is pushing a lot of heat
Old 03-03-2015, 05:15 PM   #13
TonyNDeb
Drives: Candy
In this weather, no.
TonyNDeb is offline   Reply With Quote
Old 03-03-2015, 07:33 PM   #14
macalot
macalot's Avatar
Same here.
