Old 03-01-2015, 09:19 PM   #1
ZEELWN
ZEELWN's Avatar
Drives: 2013 Camaro ZL1 Black
Impatientz
OK.... So I have been a good boy all winter. The car has been in a heated garage just waiting to get out.
Did you ever start questioning why they would put heated seats and heated mirrors or a heater for that matter in a car that comes with tires meant for summer only?
I admit it, this past week when the weather cleared up but the temperatures were in the low 20s I decided to take it for a little spin. The main roads were clear, the side roads were snow packed. The tires have 14k on them and will need replaced soon anyway so who cares if they crack? How bad could it be if I went a few miles carefully?
The news here is that the car did not veer into the ditch on its own (I was being very careful). Note that things are really slippery on cold and snow but not much worse than my 2wd pickup. On the 3 blocks that were snow packed I turned on the PTM mode 1 for wet. OMG it was cool, really did sense the slip of tires and would constrict power easily making the experience fun.
Any others using PTM 1 for winter in the Z? Any one else desperate enough to drive this winter that will not end?
2013 ZL1
ZEELWN is offline   Reply With Quote
Old 03-01-2015, 09:40 PM   #2
Red Jewel RS
Red Jewel RS's Avatar
Drives: 2010 Camaro 2SS
I used PTM 1 last year it was cool how it worked. I then went thru each PTM and now I understand what each will do to the car. Driving the car on snowy road is a great way to learn what PTM is all about.
Red Jewel RS is offline   Reply With Quote
Old 03-02-2015, 08:04 AM   #3
Jeb114
Jeb114's Avatar
Drives: 2021 300
They have heated seats, and a great Heater because 98% of the cars out there are Dailey Drivers. And most of us get rid of those tires and buy all around performance tires.
Jeb114 is offline   Reply With Quote
Old 03-02-2015, 08:16 AM   #4
rvnmaniac
Drives: 2012 M6 ZL1. 2019 Altima.07 FJR1300
+1.... Conti DSWs Rule.... But I still don't drive in the snow. Cold weather doesn't stop though. GYS are horrible below temps of 50 or 40 degrees F.
rvnmaniac is offline   Reply With Quote
Old 03-02-2015, 09:05 AM   #5
HDRDTD
Also very handy when the temps dip below 65 and the top is DOWN.
Old 03-02-2015, 08:27 PM   #6
ZEELWN
ZEELWN's Avatar
That is my plan once these tires are worn out. Have noticed the heater is better than any I have had before.
2013 ZL1
Old 03-02-2015, 08:31 PM   #7
ZEELWN
ZEELWN's Avatar
Those are the tires I have picked out also. 540 treadwear should mean a lot of miles. So they do not make the exact size as original what sizes did you end up with on the Conti DSW?
I am leaning towards the 315/35ZR20 rear and 285/30ZR20 front but not sure about the 30 front aspect ratio.
2013 ZL1
Old 03-02-2015, 08:48 PM   #8
OVERPAR73
2018 Garnet Red ZL1 conve
OVERPAR73's Avatar
Drives: 2013 & 2018 ZL1 vert
I think your crazy driving in the cold & snow! You might be in luck on Sunday if it gets nice for us?
Build Thread: 2018 ZL1 Vert Purchased (Overpar73)
OVERPAR73 is offline   Reply With Quote
Old 03-04-2015, 12:25 PM   #9
2014CamaroZL1
2014CamaroZL1's Avatar
Drives: 2014 CRT ZL1
It's a car.
Drive it and enjoy it as much as possible.
Why take the depreciation hit and save it for the next guy ?
ZL1 Camaro - Worlds Largest Sports Car
Road King - Not Garage Queen
2014CamaroZL1 is offline   Reply With Quote
Old 03-04-2015, 01:59 PM   #10
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
That tire size setup may be too large of a difference in the Overall diameter of the front and back tires, which could cause issues.
The biggest split I have seen is 315/35 in back and 285/35 in front(Michelin PSS's).
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 03-04-2015, 05:02 PM   #11
Mishaman68
Drives: 2017 ZL1 M6
Right there man. That's the magic statement for us vert guys.
Mishaman68 is offline   Reply With Quote
Old 03-04-2015, 06:32 PM   #12
Ryzer
Drives: '14 AGM ZL1
I do question why they didn't add in cooled seats, would be nice on a warm day. Not that we get many of those up north.
Ryzer is offline   Reply With Quote
