Old 03-14-2015, 05:08 AM   #1
keith.wilkinson.10
keith.wilkinson.10's Avatar
Drives: 2010 2SS/RS IBM
Stainless Steel brake lines
Just wanted to stir up some chatter. How bad do I need these. I'll use a good dot4 and maybe a track pad on track days but what about the lines.
I found these I like the red pvc coating
http://www.jegs.com/webapp/wcs/store...&storeId=10001
keith.wilkinson.10 is offline   Reply With Quote
Old 03-14-2015, 10:41 AM   #2
Rob@WretchedMS
Drives: His Wife Crazy
Stainless lines are great if you are doing track days.
I like the Russell Lines, we sell those for about the same price (but they are backordered again), as well as the Agency Power Lines also for about the same price, (1 set of them left)
We also carry the Goodrich lines, they are a bit more expensive, but are more available
either way you can't go wrong, they are all good options.
Rob@WretchedMS is offline   Reply With Quote
Old 03-14-2015, 10:49 AM   #3
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
For track use braided lines are a must. For street use they are a nice upgrades. Braided lines will improve brake feel and performance but also add an extra layer of safety.
Old 03-16-2015, 12:22 PM   #4
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
I went with the Goodrich lines and DOT4 fluid when I did the CTS-V upgrade on my daily driver. It just made sense.
Now when I'm driving to work and have to stop quickly in traffic, my concern is no longer "will I stop in time" but rather, "will the guy behind me stop in time."
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 03-16-2015, 04:35 PM   #5
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
Buy ones that will work on the ZL1/CTS-V calipers. They are a little longer than the SS, but it you ever decide to upgrade calipers, you won't be buying new brake lines again.
bannonm is offline   Reply With Quote
Old 03-17-2015, 12:41 PM   #6
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Stainless Steel brake lines are a great upgrade. I highly recommend them along with a good DOT 4 Fluid.
I would suggest spending a little more for the Goodridge lines though. Part # 12219 is what you need for the SS and part #12227 for the ZL1 or SS's doing the CTS-V brake upgrade. (you can use the 12227 lines on stock SS calipers as well)
Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 03-17-2015, 03:08 PM   #7
ActNup NY
ActNup NY's Avatar
Drives: 2011 1LT Black Camaro
Best regards,
Tyler
888-308-6007
So Ty what about a v6 doing an SS brake upgrade could I too use the 12227 as well?
The DREAM is free... It's the HUSTLE that is sold seperately
ActNup NY is offline   Reply With Quote
Old 03-17-2015, 03:14 PM   #8
JDP Sales
JDP Sales's Avatar
Yeah, you could, but if you're just going with the SS calipers, I'd stick with the 12219 lines.
Best regards,
Tyler
888-308-6007
Old 03-17-2015, 04:26 PM   #9
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
+1. Any brake upgrade is a worthwhile upgrade.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 03-17-2015, 04:54 PM   #10
Mike_G
Drives: 2010 2SS/RS
When I installed stainless lines I didn't notice at the time but one of the old crush washers on the rear stayed on the caliper so now there is an extra. It seemed to seal up fine with it there. Should I remove it and replace with two new washers or should it be fine with the extra used on still in there. I have the old used one/ new one/ line/ new one/ banjo bolt. No leaks as of right now.
Mike_G is offline   Reply With Quote
Old 03-17-2015, 08:18 PM   #11
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Stay away from the Racing Brake lines (or others like them). They are junk! Had to replace all four of mine when I rebuilt my calipers. Went with the Russel lines. Great price and reuses the OEM banjo bolts.
Avalnch is offline   Reply With Quote
Old 03-17-2015, 11:11 PM   #12
Assassinx1
Drives: Corvettec5
I have a set of zl1 good ridge front lines for sale $125 shipped.
Assassinx1 is offline   Reply With Quote
Old 03-17-2015, 11:31 PM   #13
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
I'm thinking about getting these http://www.phastekperformance.com/20...es-5th-gen.htm . Are they any good?
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 03-18-2015, 03:26 AM   #14
keith.wilkinson.10
Having two copper washers is not a problem they will crush to seal; no leaks no problem.
I feel as if an uncoated ss line would be subject to failure before a coated or even steel braided rubber hose. Even SS can rust; especially a lower grade like 304. Also may be possible to embed dirt in braids and add to the deterioration.
I'm interested if anyone knows bursting pressures and temp ratings for OEM style and aftermarket.
I assume they are longer to reach the connection on the caliper. Is that correct?
