![]() Drives: [COTW 8/3/15] 2010 Camaro SS L99 Join Date: Mar 2015
Coilover /Swaybar Question
For you that are running coilovers, what swaybars are you running with them? Are you still running the stock bars? If not which bars are you running? Have you noticed a big diffrence going to an aftermarket bar after running coilovers?
A Little bit of power. ALL WORK DONE BY ME!
Just added 2021 ZL1 1LE to the Stable! https://www.camaro5.com/forums/showthread.php?t=418273 ![]() |
Flying da helicopter
I have pfadt sway bars with ridetech coilovers. The handling is 100% better over stock.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Megan Racing Coilovers w/LSR sways. Virtually no body roll.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
Casey Woodside
Drives: a very fun car Join Date: Jun 2010
are you on the fe3 or have you upgraded to the fe4 set up?
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w |
Sway bars make a great addition to coilovers. Add in a few key arms and bushings and you've got a great handling car.
I suggest going with either the BMR bars or Detroit speed bars. The DSE bars are a little stiffer and a little more expensive, but worth it. Feel free to call, PM or email me anytime with questions. Best regards, Tyler 888-308-6007 |
