![]() Drives: 06' Avalanche Join Date: Jun 2009
Void Warranty?
will having the mufflers removed/straight piped void the warranty?
![]() Drives: 2010 Camaro 1LT/RS, 6M, IBM Join Date: Jul 2009
![]() Drives: 2010 1LT RS Join Date: Jun 2009
#4 | |
PWA Relapse
![]() But it also netted 16 horsepower on the dyno, so if you're looking for cheap horsepower with no regard to sound, this is a good way to do it. - X
2017 1LT/RS A8 Hyper Blue Metallic |
#5 | |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
I'm not sure I could live with that sound even if it netted 100HP!!!
#6 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 SVT Raptor, sold 2010 Camaro Join Date: Jul 2009
#7 |
Drives: black Join Date: Aug 2009
Good luck!
#8 |
Rolling along...
I've been wondering how much the stock resonators have to do with messing up the sound of the V6. I mean, just listen to the exhaust of all the ones that people have done so far. The two things most of these systems have in common is that some sort of X pipe is added and the stock resonators are removed/replaced.
The Corsa system adds an X pipe and uses Corsa's resonators. The Borla Cat-back system adds an X pipe and removes the stock resonators. The MBRP system adds an X pipe and removes the stock resonators. The MRT (scrming's) system is basically double resonated with the stock resonators and a pair of AR25's. Suavecito1177's custom Magnaflow setup gets rid of the stock resonators but uses a single muffler with Magnaflow's Tru-X design (built-in X pipe). I'm thinking that maybe getting rid of the stock resonators and adding an X pipe will help out the sound of this car a lot.
#9 |
The stock exhaust already comes with an H-Pipe. Not sure what the difference would be between an X and an H pipe though.
#10 | ||
Rolling along...
Both are good for performance and noise control but H-pipes tend to help with performance more than X-pipes. Excerpt from a really good article on exhaust systems: http://www.superchevy.com/technical/...exh/index.html Quote:
#11 |
In general and in the v8 world x-pipes are regarded as being more high pitched and raspy than the h-pipe... check any of the car forums... they all seem to agree on that part at least... LOL
Not sure if that still applies to the V6 world but when we built a custom dual exhaust for my V6 Mustang Scott (MRT) built me an H-pipe... His take is the H sounds better...
#12 |
![]() Drives: Camaro 2SS/RS Join Date: Aug 2009
I like the sound of H=pipes better.
So is anyone making them for the Camaro?
#13 | |
Rolling along...
Not sure about the SS since I don't own one and really haven't followed those threads as much.
#14 |
I read there was on stock. but I'm thinking if I doe LTs and a catback that will be gone. Was wondering if there were any on the market as a seperate piece.
| Your Warranty Rights | The_Blur | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 75 | 10-19-2012 08:24 PM |
| IMPORTANT Part 1 Warranty Disputes | Zeus | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 11 | 08-25-2009 12:37 PM |
| Does a supercharger void warranty or not? | OHIOSS | Forced Induction - V8 | 29 | 08-07-2009 06:40 AM |
| Paint your ground effects (GFX) at your OWN risk! Will void its warranty. | SS-Eric | Cosmetics and Lighting Modification Discussions | 71 | 08-02-2009 02:05 AM |
| will adding after market headers void warranty? | lakersftbl69 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 8 | 05-26-2009 02:07 AM |
