Old 04-02-2015, 08:13 PM   #1
noisemker
noisemker's Avatar
Drives: RY 2LT/RS
Ignition coils
I have to change 2 ignition coils and was wondering if there's anything I should know before I attempt it. How do I know which cylinder goes to which ingnition coil. Would I need to disconnect the battery? Any help would be great thanks
Airaid Intake And Solo CatBack Solo Highflow Cats
noisemker is offline   Reply With Quote
Old 04-02-2015, 08:25 PM   #2
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
I've never disconnected the battery when taking apart the coils and plugs (prob should) but never had any problems. Cylinder 1-3-5 and on the pass side of the car and 2-4-6 are on the driver side....
5---6
3---4
1---2
Front of car
kjkjr27 is offline   Reply With Quote
Old 04-02-2015, 08:32 PM   #3
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Also you will have to remove the intake manifold
Old 04-02-2015, 09:05 PM   #4
noisemker
noisemker's Avatar
Drives: RY 2LT/RS
Awesome thanks for the help
Old 04-04-2015, 07:12 AM   #5
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Each coil sits right on top of the spark plug. I've never had to remove the intake to access mine.
Here's a good DIY guide- http://www.paulstravelpictures.com/G...ide/index.html
Old 04-04-2015, 04:37 PM   #6
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
WRONG!! You just need a 10mm socket. Unplug the coil from the wire, slide it out, slide the new one in, replug the wires and tighten the 10mm bolt. You might have to turn the coil pack to the left or right to get it around the tubes and manifold. I replaced 4 over the Winter, total of 7 since I've had my car. BTW AMAZON.com sells them for $24 to $30 each, the dealer wants $90 and any Autoparts store wants about $50. I keep two spares in my trunk along with a serpantine belt $16 on AMAZON.
Eddiefuzz is offline   Reply With Quote
Old 04-04-2015, 05:40 PM   #7
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Gl on the passenger side then...
Old 04-10-2015, 01:26 PM   #8
c_cook94
c_cook94's Avatar
Drives: 2011 Rally Yellow 1LT
Eddie and vent are correct, no need in removing intake.
c_cook94 is offline   Reply With Quote
Old 04-14-2015, 12:00 PM   #9
noisemker
noisemker's Avatar
Drives: RY 2LT/RS
Were you also having misfiring issues or what caused you to replace them?
Old 04-14-2015, 07:05 PM   #10
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
Yes, this Winter was tough, I replaced 4 of them at different times and different cylinders. I would clear the code and if it came back within a few hours, i knew that the coil was bad.... A new one would solve the problem. I haven't needed a new one since February
