Old 04-13-2015, 04:16 PM   #1
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
New ZL1/CTS-V Brake Rotor Install Question
So I received my new ZL1/CTS-V brake rotors (ordered them from Amazon) and they are very "silver" in color like there is a coating of some kind on them. Is there any sort of cleaning procedure I should use when installing them other than spraying them down good with brake parts cleaner and making sure all mfg oils are wiped off?
Thanks in advance for any help/experience anyone can provide.
Nick S is offline   Reply With Quote
Old 04-13-2015, 11:47 PM   #2
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
Its not a coating, its a shot peen procedure used to stress relieve the rotor, kind of like sand blasting. Like you said just clean them with brake cleaner and your good to go.
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 04-14-2015, 01:51 PM   #3
Nick S
Nick S's Avatar
Thanks for the info!
Old 04-14-2015, 10:08 PM   #4
Mgizzle
Mgizzle's Avatar
Drives: 2013 Camaro 1LE 1SS
It is a coating/paint to prevent rust when they are sitting on shelves at dealers or on cars at dealer lots. All rotors have them when new, will come right off. Rotors do not get shot peened.
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
Mgizzle is offline   Reply With Quote
Old 04-14-2015, 10:35 PM   #5
Nick S
Nick S's Avatar
They didn't look shot peened to me since I couldn't see any "dimples" or any other evidence of being peened. But I'm not an expert in shot peening so I figured they must be really really small pieces being used in the shot peening process. But it did look more like a coating to me than shot peening.
Old 04-15-2015, 03:00 AM   #6
X25
X25's Avatar
Drives: '16 C7 Z51
+1, it's just a coat to prevent rusting so the new car buyers don't freak out. Since it has to come on new cars with that coat, it is designed to not need washing, unlike my StopTech rotors' coating.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 04-16-2015, 12:40 PM   #7
White_SS/RS
Drives: 14 1LE
Ok so get some paint remover and clean it off.
LMS Engineering
Old 04-16-2015, 03:51 PM   #8
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
Acetone
Pedders Pace Car Kit with ZL1 sway bar conversion & camber bolt kit.Lowered 1.5". 1LE tires & wheels. CAI air intake. Anvil CF rear spoiler.MGW shifter. 1 7/8" Kooks LT headers & HF cats.V-Max ported TB. Tuned.
rockrau is offline   Reply With Quote
Old 04-16-2015, 07:55 PM   #9
Mgizzle
Mgizzle's Avatar
Actually you dont want to remove the paint, some of it is on the OD and vanes so those dont rust and it can stay there for a while since those areas are not in contact. Seriously dont waste ur time with anything but just installing them and driving your car. Has no impact on your brakes.
Old 04-16-2015, 09:27 PM   #10
Nick S
Nick S's Avatar
Will do!! Thanks for the reassurance!
Old 04-17-2015, 12:55 AM   #11
White_SS/RS
Drives: 14 1LE
I was joking.
LMS Engineering
Old 05-21-2015, 12:15 PM   #12
Matty Ice
Matty Ice's Avatar
Drives: 2015 SS/RS 1LE
Nick s- Question, did you swap calipers or are you still using the stock 1le calipers with the ZL-1/CTS-V?
Matty Ice is offline   Reply With Quote
Old 05-21-2015, 12:36 PM   #13
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Not possible. You need the CTS-V/ZL1 calipers to run CTS-V/ZL1 Rotors.
Best regards,
Tyler
888-308-6007
Old 05-21-2015, 02:13 PM   #14
Nick S
Nick S's Avatar
I finally made the swap about 2 weeks ago. Have not had a chance to really test the braking improvement other than a few trips around the block to try and get them burnished a little.
Best regards,
Tyler
888-308-6007
As Tyler indicates above it's not possible to run the rotors without the calipers. The rotors are a larger diameter so your stock caliper would not clear the larger rotor.
