Old 04-13-2015, 09:10 PM   #1
ems-pilot
ems-pilot's Avatar
Drives: 2016 Silverado
Daytime RUnning Lights w/Halo - Harness
I bought this Plug and Play harness from AMAZON and finally installed it today. It connects into the harness and turns on the Halo Lights with the DRL.
Works perfectly! Quick install but didn't come with any instructions. The instruction for the harness are in the description of the part but it was really simple.
1. Turn the front wheels inward to access the star screws on the wheel well liner. (turn wheel left to access the right side and right for the left side);
2. Remove the three bottom screws only;
3. Gently pull back the liner enough to fit your arm inside (I used a knife pry it from the side of the wheel well);
4. The connector on the ZL1 is located ABOVE the fog lights. It WILL NOT fit directly on the lights themselves and has a blue faceplate just like the connector;
5. Unplug the car connector and plug in the halo connector to the relay and the car connector to the back of the halo connector;
6. Re-install the screws and DONE!
It was very easy and a quick new look for around $30 bucks
Topper
ems-pilot is offline   Reply With Quote
Old 04-13-2015, 11:14 PM   #2
2K13_ZL1_BLove
Drives: 2013 Summit White ZL1
Yep. Same harness but got it from Gen5 DIY. LOVE it. Looks sick at night. Now you just have to upgrade your bulbs.
2K13_ZL1_BLove is offline   Reply With Quote
Old 04-15-2015, 05:04 AM   #3
ems-pilot
ems-pilot's Avatar
I know...I ordered some but they arrived in ALL JAPANESE and didn't fit...Thanks EBAY!
Which bulbs should I get?
Old 04-15-2015, 05:05 AM   #4
ems-pilot
ems-pilot's Avatar
How did you get the lower bulbs on???? I cant figure them out. Yours are on at night too?
Old 04-15-2015, 09:07 AM   #5
ZeuSS2011
ZeuSS2011's Avatar
Drives: Black 2011 2SS/RS / Black 2013 ZL1
Put your finger dead center on the knob for the headlights and push in to turn on the fog lamps.
ZeuSS2011 is offline   Reply With Quote
Old 04-16-2015, 01:50 AM   #6
pontiac_4_ever
GM F-Body Enthusaist
pontiac_4_ever's Avatar
Drives: 2013 ZL1 # 3542 - Blue Ray Metallic
I bet you got a harness for a regular Camaro (even though it said it would work with the ZL1). You need to get the harness from gen5diy. Here is the link ot the correct harness - http://www.gen5diy.com/PnP_harnesses...1-drl-harness/
The cheap harness doesnt have the wire to make the fog lights on a ZL1 work. Give them a call, they will hook you up!
pontiac_4_ever is offline   Reply With Quote
Old 04-16-2015, 10:13 AM   #7
2K13_ZL1_BLove
H11 and P13 LED bulbs from Phastek. Harness from GEN5DIY. Harness keeps the DRL which are the lights underneath the headlights. Underneath those the smaller lights are fog lights. So at night when the headlights and halos come on, the DRL are on, and to get the fog lights on u just push in the headlight button. Then all the lights will be on.
Old 04-16-2015, 10:21 AM   #8
winterboy8
winterboy8's Avatar
Drives: 2015 ZL1 Blue Velvet Metallic
Any harnesses out there that will allow you to have the halos on in daytime, and no other lights??? i.e. make your halos into DRLs.
Roto-Fab CAI, ARH LT, SW 3" catback, JRE tune, Elite-2 CC, VMAX TB, Big Gulp, WW II relo, Lingenfelter S/C reservoir
winterboy8 is offline   Reply With Quote
Old 04-16-2015, 10:57 AM   #9
Expunge
Expunge's Avatar
Drives: 2013 ZL1 M6, '99 Tahoe 2Dr Sport
No harness needed for that. On the light knob turn it to the left to turn off your drl's, then turn it one click to the right and you will have halo's only.
Expunge is offline   Reply With Quote
Old 04-16-2015, 11:48 AM   #10
winterboy8
winterboy8's Avatar
Awesome, thanks dude. Guess I'll figure this out when I actually get my car. can't wait!!
Old 04-16-2015, 01:55 PM   #11
revobasher
revobasher's Avatar
Drives: 2013 ZL1
Sweet.. I am going to pick this up
2013 ZL1 - Blue Ray Metallic
JDP 850 Package
740hp/700tq @14lbs on E85
Build Thread
revobasher is offline   Reply With Quote
Old 04-16-2015, 09:25 PM   #12
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
If anyone wants a harness that has a few different settings let me know.
http://www.camaro5.com/forums/showth...08#post8366408
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 04-17-2016, 05:55 PM   #13
pinoyplaya
Drives: '13 SS RS
To be clear, this harness allows you to keep the DRL (Fog Lights) to stay on at night when your standard head lights are turned on correct?
I want a harness that will always keep my Halo Lights ON without having to turn a knob. I want the Halo lights to turn on at night or during the day when the with the DRL while the knob is set to auto at all times.
This harness will not work for me?
2013 Camaro SS RS
pinoyplaya is offline   Reply With Quote
Old 04-18-2016, 07:15 PM   #14
Steven Vaccaro
Steven Vaccaro's Avatar
Drives: 2014 Silver ZL1
This is great. Next on the list.
Steven Vaccaro is offline   Reply With Quote
