Drives: 2013 1le Join Date: Nov 2012
highest hp lsa/tvs 1900 or 2300 ls3
Who has the highest horse power with a zl1/cts blower on a ls3 stock bottom end ?
a lot of people at 560 to 600 with 8 to 10 lbs of boost who is the most powerful ? and what kinda times are they running in the 1/4 mile. Last edited by onebad1le; 04-19-2015 at 10:26 PM. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
I like to think Tuesday I will take the auto record For one!
cool
what mods and how much boost ?
This would be for the lsa blower. stock bottom end, ported heads, btr stage 3 pd cam, rotofab cai, d3pe heat exchanger and reservoir, 2.5 upper pulley (10 lbs), 4l80 trans, 3200 stall, zl1 rear. Zl1 fuel pump, adm fpcm, kenne bell 40amp bap and 1000cc injectors. This is strictly 93 but will be adding more boost and meth soon!
#5 | |
Pro Hide n Seek Player
Drives: 2010 SS LS3/LSA 620whp/630tq Join Date: May 2009
620whp/630wtq. ADM LSA Conversion, E85, PFADT Tri-Y Headers into Borla S, PFADT Swaybars, Springs, Links, 20x10 20x11 Forgestar F14s, Lots of AAC |
#6 |
Final tune tuesday! I'm definitely excited
#7 |
![]() Drives: 2017 zl1. Headers intake pulley e Join Date: Oct 2014
im at 661!! stock ls3 bottom
#8 | |
![]() Drives: Autobot Join Date: Jan 2015
I think he had a replica GT9 cam, AFCO heat exchage, meth maybe e85 tune, heads just about all you can do.. but I would ask him to be sure.. great guy easy to talk to.. but shop has had some real quality issues with at least 4 of us Htown members.
#9 | |
#10 |
![]() Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
803 wrhp/752 tq stock bottom end LS3 with tvs2300, 1/2" RDS spacer, cam and 102 mm throttle body on E74.
#11 |
660 with 1900, 714 with 2300. Automatic
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80 “1360 Rwhp 1225 Rwtq 25 lbs of boost” |
#12 |
So it's got piston oil squirters 9.1:1 compression vs 10.8.1
sounds like he just wanted to no what you can get out of that small blower..
#13 |
I think it was more or less what a ls3 lower will hold up to!
#14 |
High limits
Want to see how much I can turn it up and see what's the zl1 blower is capable of
Might put on a 2.5 pulley and run 15lbs of boost and race gas |
