Old 04-20-2015, 10:04 PM   #1
peterosorio94
Drives: 2012 Camaro Ls
Throwout bearing! HELP
I've been feeling it for a while, the clutch pedal is had some play (vibration) in it, and when turning off the car I can feel the clutch pedal shaking and a audible noise. Now it is making a loud clanking sound at certain rpm's, the throwout bearing has obviously failed. I am aware that the slave cylinder assembly comes with a new throwout bearing and it is all in one piece, but it is $280 WOW!!.. so anyone got a clue as to the shaft diameter and what not and where I can get the Throwout bearing by itself.
Thanks so much in advance👌👍
2012 ls Camaro relatively stock, 53k
peterosorio94 is offline   Reply With Quote
Old 04-20-2015, 11:11 PM   #2
Bizaro
Drives: 2015 Redhot 1LE
Please upgrade your release bearing support too read this.
http://www.camaro5.com/forums/showth...billet+release
Bizaro is offline   Reply With Quote
Old 04-20-2015, 11:24 PM   #3
peterosorio94
I have access to a full hydraulic lift, don't mind doing the labor twice, I'm 21 years old don't really feel like dropping $800 even though I would love a new clutch and pressure plate, I don't really care for the feeling of a lightweight flywheel so that's something I would skip. But like I was saying cost, I'm sure the bearing couldn't be any more than 40-50$...?
Old 04-20-2015, 11:36 PM   #4
Bizaro
that is correct ~40 USD give or take
Old 04-21-2015, 12:25 AM   #5
peterosorio94
Does anyone have the part number on the release bearing or as to what manufacture I can start getting ideas from. I feel like I'm going to further damage parts if it doesn't get replaced relatively soon. And I would leg to stay as far away from replacing the entire slave like I said. Hopefully replace it with something a little beefier.
Old 04-21-2015, 07:49 AM   #6
Dfault
Dfault's Avatar
Drives: 2014 Camaro SS
Gotta love when a 21 year old is turning down sound advise from someone older and wiser.
Anyway, you're going to be running into more problems once you fix that throw out bearing. Just take into consideration what other part may have gotten damaged from one part not being completely functional.
Dfault is offline   Reply With Quote
Old 04-21-2015, 07:53 AM   #7
stratman2SSRS
stratman2SSRS's Avatar
Drives: Lingenfelter Camaro
Take it to the dealership and get it replaced under warranty.
It should be covered.
stratman2SSRS is offline   Reply With Quote
Old 04-21-2015, 08:58 AM   #8
MCSarge
USMC 1980-1990
MCSarge's Avatar
Drives: 2010 Camaro 2SS/RS
You may be correct, but in the past I have not heard of them repairing any "consumable" parts in the clutch. Mostly due to the abuse they can be exposed to...not that any member here would be doing burnouts or racing or anything like that...
USMC 1980-1990
My other toys are Harleys
MCSarge is offline   Reply With Quote
Old 04-21-2015, 09:36 AM   #9
velocity149
velocity149's Avatar
Drives: 2014 2SS RS LS3
As long as your under powertrain warranty, you'll have that replaced. My clutch constantly stuck, and they replaced whole slave cyl, clutch plate, and resurfaced flywheel.
Thank our veterans for peace today, Support our troops for peace tomorrow. RIP Dad, 1962-2012 SYOTOS
velocity149 is offline   Reply With Quote
Old 04-21-2015, 11:24 AM   #10
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
IDK, when I was a broke azz 21 year old, I probably would just replace the bearing too. Time is money and when your 21 time is not as expensive.
Old 04-21-2015, 11:28 AM   #11
peterosorio94
I will go in the dealer, I assumed it was a wearable item an non repairable, and sound advice is 280$ for a part that is going to fail again. From what I've read on the fourm this is a common issue and had ruined peoples clutches and caused breaks to fail due to lack of break fluid. Im more looking for a fix, not a bandaid that will fail in another 30k and if the only fix is replacing, I would like to replace the cheapest wearable part AKA the plastic sleeve and the bearing.....
Old 04-22-2015, 02:53 PM   #12
peterosorio94
Oh no, The part completely failed locking the flywheel and the car will no longer start stalled while driving I was able to clutching and pullover, I'm being towed to a dealership right now.
Old 04-22-2015, 03:51 PM   #13
Dfault
Dfault's Avatar
I saw this coming, but i hope you get your issue taken care of!
Old 04-22-2015, 04:39 PM   #14
CamaroCracka
I don't think that is what he's saying unless he took his trans out last night.
bolt ons, exhaust, ls series, lsx, manual
