Old 04-22-2015, 10:24 PM   #1
Itwuzalladream
Itwuzalladream's Avatar
Drives: Street Car
What type of power should i expect???
I have a 2010 SS automatic with:
2300 maggie
3.0 pulley
Comp lsr cam 239/243 .624/.624 114
Ported heads
Dod vvt delete
Rotofab cai
Magnaflow exhaust
Cooks longtubes
Aem meth kit
ZL1 fuel pump
Kenne bell bap
Fast 90lb injectors
160 thermostat
Yank 3200 stall
Trans cooler
Mti belt tensioner
18" zr1 wheels 305/45/18 mickey thompsons
Going in for tuning soon by Dr. Phil
What is a reasonable power estimate i can expect? Also is this enough to get into the 10's in 1/4 mile?
Itwuzalladream is offline   Reply With Quote
Old 04-23-2015, 12:51 AM   #2
SuperchargedStealth
Drives: '11 Camaro Supercharged Convertible
550-650 range. 10's.....possibly. If you no suspension upgrades done then you'll have a hard time hooking up, and if you do, most stock axles are weak, and tend to break. I say most because I have seen some stock axles hold together. If you want to run 10's more then once, look into new axles and suspension upgrades. By upgrades you can do the minimum by getting trailing arms and toe rods. You can install them yourself, but since your car will be at a shop let them go through the headache of getting the bushings out. If you don't hit 10's you'll be damn close.
2011 Triple Black SS convertible, LSX 427, PRC 260cc heads, Callies Ultra Billet Rods, Wiseco -20 cc piston, Callies Dragon Slayer crank, Strange Dana 60 rear w/3.73 gear ratio and driveshaft, Pfadt coilovers, Pfadt sway bars, Pfadt trailing arms, Pfadt tie rods, Pfadt subframe bushings, Vortech YSi with wastegate and twin BOV, Haltech ECU, Mantic 9000 Twin Clutch, ALKY control meth system with dual nozzle, Squash twin fuel pumps, ACS T3 ports, VIS Terminator Hood, Seibon ZL style lip.
SuperchargedStealth is offline   Reply With Quote
Old 04-23-2015, 04:51 PM   #3
old motorhead
Drives: Maggie blown LS3 vette
2300 maggie
3.0 pulley
Ported heads
Dod vvt delete
Rotofab cai
Magnaflow exhaust
Cooks longtubes
Aem meth kit
ZL1 fuel pump
Kenne bell bap
Fast 90lb injectors
160 thermostat
Yank 3200 stall
Trans cooler
Mti belt tensioner
That's a horrible cam for a Maggie rig with an A6. Also, overdrive your rear pulleys and run a 3.5" up front. Same blower speed as a 3.0" with 1:1 rears. Much less likely to slip. You should be mid 600's with a more appropriate cam and no belt slip. 10's sholdn't be a problem.
old motorhead is offline   Reply With Quote
Old 04-23-2015, 08:07 PM   #4
Itwuzalladream
Drives: Street Car
What is the problem with this cam??
Old 04-23-2015, 08:31 PM   #5
old motorhead
If you have it already installed, and you like it, run it and enjoy. You can make the same, or more power with a well specced, p/d blower specific custom cam though. You don't need a big cam with a lot of overlap under a TVS blower. If you're not already committed on the cam, get one of the cam guru's to spec you one. You can have your cake and eat it too with a milder/TVS specific cam. All the power of a much bigger cam without the crappy drivability issues. If you want the bad a$$ed idle along with the buck and surge of a big cam, you're there with that cam.
Old 04-23-2015, 08:43 PM   #6
Itwuzalladream
Drives: Street Car
Thank u so much for breakin it down for me! Yes it is already installed, im just waiting on tuning and its ready for the summer... I do love the bad a$$ aspect but i wouldnt have had a problem with sumthing more practical either... My biggest thing is to run 10's though
Old 04-23-2015, 08:46 PM   #7
old motorhead
I don't think you'll have a problem at all running 10's. I can't argue with the big cam sound though
Old 04-24-2015, 06:38 AM   #8
2010SSRSM6
2010SSRSM6's Avatar
Don't think your going to have enough fuel pressure. It's going to be tight unless they are using the meth as fuel, which I wouldn't do.
Hope your ok, but get a fuel pressure gauge quickly. Last thing you want to do is go lean and starve the motor.
Old 04-24-2015, 08:37 AM   #9
SuperchargedStealth
He should be fine with fuel. He's running a ZL1 pump along with a BAP. That's plenty to accomplish what he wants.
Old 04-24-2015, 10:37 AM   #10
2010SSRSM6
2010SSRSM6's Avatar
My pressure dropped at 620rw through a manual. Not all pumps are created equal I guess.
Old 04-24-2015, 05:48 PM   #11
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
OP I was running mid 10s at 585 rwhp with the stock pump and a bap. Now running low 10s at 633 rwhp with fuel up grade.
Don't wheel hop it your axles and diff should be ok at the 600 rwhp mark. I would worry more about the transmission
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 04-24-2015, 07:56 PM   #12
Itwuzalladream
Drives: Street Car
Thank you for the info! I hope nothing breaks atleast this season lolll
