Old 05-12-2015, 02:45 PM   #1
Shabers3
Shabers3's Avatar
Drives: 2013 Camaro SS
Side Pipes
I was thinking about putting the stainless works side pipes on my 13' SS. Does anyone know how the ground clearance is on them and if they work well with cutouts.
Shabers3 is offline   Reply With Quote
Old 05-19-2015, 02:58 PM   #2
J-Crazy Camaro
J-Crazy Camaro's Avatar
Drives: Red V8
I would call the company, here is the link to the product, going off this picture its looks like you still have a good amount of clearance.
http://stainlessworks.net/chevy-cama...odular-exhaust
Live Hard, Drive Fast, Die Free. 'Merica
J-Crazy Camaro is offline   Reply With Quote
Old 05-19-2015, 07:17 PM   #3
Chris1SS1LE
Chris1SS1LE's Avatar
Drives: 2014 Camaro Red Hot 1LE NPP Recaro
Looks like its at the same level as the pinchweld. They are pointed more down then out. So clearance should not be a issue.
I would like to hear one with a factory NPP installed
Chris1SS1LE is offline   Reply With Quote
Old 05-19-2015, 07:41 PM   #4
Irace16
Irace16's Avatar
Drives: 2010 1SS RS M6
I thought you meant the old school ones that run up the side of the car , that would be a cool option...
Vararam intake, gmpp exhaust, borla stainless long tubes, cat less, jannetty tune, bmr lowering springs, heritage grill , smoked lenses
Irace16 is offline   Reply With Quote
Old 05-19-2015, 07:54 PM   #5
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
I wonder if the side pipe kit comes with block outs for the OEM exhaust holes...
TheHorse13 is offline   Reply With Quote
Old 05-19-2015, 08:05 PM   #6
'14-ELLIE
'14-ELLIE's Avatar
Drives: 2015 2SS/RS 1LE
I doubt it. But I just had a thought... Would look pretty cool to get some ZL1 rockers and have some custom exhaust holes installed in them for this exhaust.
'14-ELLIE is offline   Reply With Quote
Old 05-19-2015, 10:27 PM   #7
xc_SS/RS
Drives: 2010 Camaro SS/RS
Seems odd how they would just cut a hole out of the stock pipes and put these on... Shouldn't you cut the stock exhaust off?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 05-20-2015, 06:37 PM   #8
Dave@Sturgiscamarorally
Dave@Sturgiscamarorally's Avatar
Drives: 2010 ABM 1SS
I was thinking the same thing... kinda defeats the purpose.
2010 Aqua Blue 1SS
KWC 3pc forged, Seibon hood, ZL front end, MGW, ARH full exhaust w/ Doug Thorley axle back, BTR4, Roto-fab, LSXR 102, NW 102, 3.91s
Dave@Sturgiscamarorally is offline   Reply With Quote
Old 05-20-2015, 08:20 PM   #9
Chris1SS1LE
This doesn't remove the system, it adds to it. Just like the side exits on a BOSS 302. Sorta like cut-outs that are open all the time, but are not in direct path or be like if you drilled a hole in your muffler or when your car gets old and your exhaust rust out and makes a hole.
cutouts, side pipes
