Old 05-23-2015, 04:25 AM   #1
mohdhooti
Drives: ls3 camaro
compressor clutch not engaging,,, help
Hi guys
2011 ls3 camaro camaro compressor clutch not engaging what's could be the problem?
mohdhooti is offline   Reply With Quote
Old 05-23-2015, 03:37 PM   #2
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Low on freon? If it is low the compressor won't kick on...YouTube is a good place to find,trouble shoot AC problems....pull the cap off the low pressure side and briefly push shrader valve to see if system is pressurized,has any freon in it. If there's no pressure you have bigger problem than average Joe can fix... Good luck
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 05-23-2015, 03:54 PM   #3
SS Blinder
SS Blinder's Avatar
Drives: 2011 SS (Sparrow Spearer???)
if you do have Freon, then check fuse 1(AC compressor clutch) in the engine compartment fuse block, if this is ok, check relay k216 (AC compressor clutch as well), also in the engine compartment fuse block
Black magic woman, don't turn your back on me baby!
SS Blinder is offline   Reply With Quote
Old 05-23-2015, 05:14 PM   #4
mat300z
Emerald Coast Camaro's
mat300z's Avatar
Drives: 2014 ZL1
Yeah..if the freon is low which is usually the case the compressor will not kick on...this is because of a low pressure switch that keeps the compressor from burning itself out.
mat300z is offline   Reply With Quote
Old 05-24-2015, 04:18 AM   #5
mohdhooti
Drives: ls3 camaro
Originally Posted by mat300z View Post
Yeah..if the froen is low which is usually the case the compressor will not kick on...this is because of a low pressure switch that keeps the compressor from burning itself out.
The problem is its work sometime and sometime not working
Old 05-24-2015, 05:57 PM   #6
mat300z
mat300z's Avatar
Drives: 2014 ZL1
it is low freon...get it checked...the low pressure switch is causing the clutch to cycle
Old 05-24-2015, 08:17 PM   #7
BurnedRubber
Ben Rakers
BurnedRubber's Avatar
Drives: 2011 Camaro 2SS/RS
i would not press in the valve to see if you have refrigerant in your system. i work on HVAC and thats not the way to check if things are ok. have a professional hook up a set of gauges to it.
2011 Camaro 2SS/RS K&N Blackhawk Cold air intake, Hawk Performance Ceramic pads, BAER drilled and slotted rotors, Side louver black faded inserts, Hurst Short Throw Shifter, BMR Trailing Arms, Elite Engineering Catch Can, MSD Spark Plug Wires, Texas Speed 1 7/8in Headers and cat back, High Flow Cats, 3 inch X-Pipe, Speed Dawg shift knob, Tuned by Nickey. And oh, its My first car.
https://www.youtube.com/channel/UC_L...5jF6EQEoKDNQ2g
BurnedRubber is offline   Reply With Quote
