![]() Drives: 2013 ZL1 Join Date: Oct 2014
Drag settings
What PTM do you guys run? Or are you just using tour and sport modes? Auto guys in M or D??
KaBoom1701
Look for "PTM modes misunderstood" topic I created for good info
Mods:
GuitarmageddonZL1
Drives: ‘13 ZL1, ‘17 TT ZL1, ‘17 Silverado Join Date: Feb 2015
You should start out in "M" because it starts in 1st gear and has tighter shifting, unlike "D" which starts in 2nd gear and has a more laid back shifting. I would assume that PTM 5 "Race Mode" would have the best performing traction setting.
![]() ![]() ![]() ![]() ![]() ![]() Drives: none Join Date: Aug 2011
Car in your Sig?
On a tire? Shut it all off. |
![]() ![]() Drives: 2013 ZL1 Join Date: Jan 2015
Turn everything off if you know how to drive.
Put it in M and let the transmission do the shifting.
2013 A6 ZL1
#6 |
#7 |
![]() Drives: 2015 ZL1 Coupe A6 & 2002 ZO6 Join Date: Apr 2014
Turning Everything Off
How is this done? Holding the traction control button down for 10 seconds?
2015 ZL1 A6 Coupe Crystal Red
ATI Balancer w/9.55 (22.5%) lower pulley, FIC1000 Injectors, Stainless Works 2" headers, Stainless Works Retro Cat-Back, V-Max Ported TB, Roto-Fab w/Big Gulp, Elite 2nd Gen Catch Can, Jannetty Tuned. 581 rwhp |
#8 |
I think it's closer to five or so seconds but yes. Once the second yellow light is on the computer about no longer interfere.
2013 A6 ZL1
