![]() ![]() ![]() ![]() Drives: 2015 Blue Velvet Metallic ZL1 Join Date: Nov 2013
Question for Auto ZL1's: D or M
Recently, I just started driving my ZL1 in the M (Sport mode) without using the paddle shifters and liked the response on both acceleration and de-acceleration with the tranny shifting. As this was a new "discovery" for me, any fellow members drive in this mode all the time and will it promote any faster wear & tear on the tranny?
I drive in sport mode almost exclusively. No aditonal wear that I know of. Hurts the mileage somewhat.
2013 Camaro ZL1, Crystal Red, Auto, Exposed Carbon Fiber, Navigation.
![]() ![]() ![]() Drives: 2017 ZL1 Join Date: Aug 2009
Yeah, I drive mine in M mode all the time too. It would start off in 2nd gear otherwise.
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY https://youtu.be/Lcu41obbTf8 '13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight. http://youtu.be/yggIA3C_kkA 2014... back to stock http://youtu.be/spQLaTWbThs 2013... stock & RotoFab |
11.91 ET Bone stock
Drives: 2015 Camaro ZL1 Join Date: Nov 2014
I always drive in M.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 ZL1 - #670 Join Date: Jun 2009
Sport mode in both cars ...
#6 | |
Also, just started to use this method after my 10% pulley/damper/tune upgrade and my tuner suggested it. |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
M all of the time! No extra wear in M.
#8 |
GuitarmageddonZL1
Drives: ‘13 ZL1, ‘17 TT ZL1, ‘17 Silverado Join Date: Feb 2015
I use both. Depends on what I'm doing.
#9 |
Snake Eater
Drives: 2012 AGM ZL1 Join Date: Oct 2011
If the car is tuned you will definitely start seeing a difference in mileage. I began driving in D because I noticed the gas mileage loss in M due to getting into my power band earlier.
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ Follow me on instagram: http://www.instagram.com/snkeatr/ |
#10 |
I use "D" until oil warms up (keeps rpm's lower) and then "M" and mostly tap shift as well.
#11 |
![]() Drives: 2014 ZL1 Black on Black Join Date: Jan 2015
I normally run M in PTM mode 4 if im cruising around. D if I am stuck in traffic and feeling lazy.
#12 |
![]() Drives: 2015 ZL1 Coupe A6 & 2002 ZO6 Join Date: Apr 2014
What would be the best for the drag strip? M & PTM 5? I'm still trying to get used to my auto and can't seem the best way to launch the car on street or strip.
2015 ZL1 A6 Coupe Crystal Red
ATI Balancer w/9.55 (22.5%) lower pulley, FIC1000 Injectors, Stainless Works 2" headers, Stainless Works Retro Cat-Back, V-Max Ported TB, Roto-Fab w/Big Gulp, Elite 2nd Gen Catch Can, Jannetty Tuned. 581 rwhp |
#13 | |
KaBoom1701
PTM 5 with drag radial tires.
Mods:
#14 |
![]() Drives: 2012 Chevrolet Camaro ZL1 Join Date: Apr 2015
Does the car make less power in non PTM 3-4 modes all the time, or does it only affect power cut during cornering/etc when traction is lost? Just curious when you're driving around the street if straight line performance with traction is reduced by not being in PTM 3-4. Does the tranny shift harder or differently in PTM 3-4 vs other modes or just the same?
